Hello guys! I new to PlatformIO, and not so understand how it works. Used to use only Arduino IDE before.
My board is Arduino Pro Mini ATmega328 5V, 16 MHz (board = pro16MHzatmega328)
I have installed external lib
Which i need to convert CRSF protocol from RC receiver to PWM and control servos.
I tried to build and flash default main.cpp, it builds, but not flashes to my board.
I found in platformio.ini some lines, that obviously must be changed for my board.
I tried this:
[env_common]
upload_protocol = avr-stub
debug_tool = avr-stub
build_flags_cdc =
-DUSBCON
-DPIO_FRAMEWORK_ARDUINO_ENABLE_CDC
# The idea here was to make a CDC version with debugging info
# and an env to build as a HID joystick, but turns out it
# isn't in the core so the feature isn't worth me implementing it
[env:F103_serial]
extends = env_common
build_flags = ${env_common.build_flags_cdc}
-DTARGET_BLUEPILL
[env:CC3D]
-DTARGET_CC3D
[env:PURPLEPILL]
-DTARGET_PURPLEPILL
And got many errors like this:
/Users/user/.platformio/packages/framework-arduino-avr/cores/arduino/HardwareSerial.h:143:25: note: previous declaration as 'HardwareSerial Serial'
extern HardwareSerial Serial;
*** [.pio/build/PURPLEPILL/FrameworkArduino/IPAddress.cpp.o] Error 1
Now the main question is how to change it, what i must type here? Or globally, how to make it build and flash to my board?
Thanks in advance for your attention!
