I am trying to upload via stlink to a bluepill - but it fails.
The error message isn’t particular helpful.
<lambda>(["upload"], [".pio/build/bluepill_f103c8/firmware.elf"])
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, mbed, stlink
openocd -d2 -s /Users/tcurdt/.platformio/packages/tool-openocd/scripts -f interface/stlink.cfg -c "transport select hla_swd" -f target/stm32f1x.cfg -c "reset_config none" -c "program {.pio/build/bluepill_f103c8/firmware.elf} verify reset; shutdown;"
xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2021-10-17-00:18)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
hla_swd
Info : DEPRECATED target event trace-config; use TPIU events {pre,post}-{enable,disable}
none separate
Info : clock speed 1000 kHz
Error: open failed
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
Maybe this is because this is using OpenOCD x86_64 while I am on an arm64 machine? Although even that should in theory work through Rosetta2.
Any pointers?
Can you still upload via the Arduino IDE? What is the invocation for the OpenOCD when you activate File → Preferences → Verbose Upload and then upload?
I need to check. It was a different, x86 machine. Maybe I can try the old install.
I don’t have the Arduino IDE on this machine. I am planning to go pio only
After searching through a few tickets on github I found suggestions to change ~/.platformio/packages/tool-openocd/scripts/target/stm32f4x.cfg
# original
# reset_config srst_nogate
# working
reset_config srst_nogate connect_assert_srst
# untested
# srst_only separate srst_nogate srst_open_drain connect_assert_srst
…and it suggests the upload with the stlink worked afterwards.
debug_level: 2
hla_swd
none separate
Info : STLINK V2J17S4 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.246123
Info : stm32f1x.cpu: Cortex-M3 r1p1 processor detected
Info : stm32f1x.cpu: target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for stm32f1x.cpu on 3333
xPSR: 0x01000000 pc: 0x0800014c msp: 0x20005000
** Programming Started **
Info : device id = 0x20036410
Info : flash size = 64kbytes
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
What is the exact code running on it? Also, some boards have their on-board LED on different pins (PC13 / PB12). Is it a regular bluepill board or a barebones STM32F103C8 chip? Are the BOOT0/1 jumpers on the board set to both GND so that the chip boots from flash (and will not go into bootloader mode)?
I have 5 boards seemingly of the same kind.
1 board just uploads and blinks.
1 board just uploads - but does not blink. (broken led?)
3 boards where the upload fails like this:
debug_level: 2
hla_swd
none separate
Error: init mode failed (unable to connect to the target)
This is with reset_config srst_nogate connect_assert_srst
I didn’t have to try the NRST route. After some tries of - writing a new bootloader and uploading with boot0 set 1, I now have 4 boards where the upload works.
I can’t say I feel comfortable as I cannot really pinpoint the final reason for the change.
But for other people reading - I was experimenting with:
$ pio run -t upload
Processing bluepill_f103c8 (platform: ststm32; board: bluepill_f103c8; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/bluepill_f103c8.html
PLATFORM: ST STM32 (15.2.0) > BluePill F103C8
HARDWARE: STM32F103C8T6 72MHz, 20KB RAM, 64KB Flash
DEBUG: Current (stlink) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-arduinoststm32 4.20100.211028 (2.1.0)
- framework-cmsis 2.50700.210515 (5.7.0)
- tool-dfuutil 1.9.211020
- tool-openocd 2.1100.211028 (11.0)
- tool-stm32duino 1.0.1
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Found 11 compatible libraries
Checking size .pio/build/bluepill_f103c8/firmware.elf
RAM: [ ] 4.0% (used 828 bytes from 20480 bytes)
Flash: [== ] 17.1% (used 11208 bytes from 65536 bytes)
Uploading .pio/build/bluepill_f103c8/firmware.elf
debug_level: 1
hla_swd
none separate
** Verified OK **
But I have 1 out 4 boards where PC13 is just constantly on.
The very same bin does work fine and blinks on the other 3 pills.
Of course I know checked the crystal and tried to visually compare the boards - but at least I don’t see a difference.
The LED also turns on immediately when the board gets power.
It’s also weird that the reset button does not seem to do anything. On the other boards the PA13 turns off during reset. Could it be a broken output?
