Cannot upload to my RP2040 zero
I use VScode with the platformIO extension, and im struggling to upload even the built in LED blink code.
CONFIGURATION: https://docs.platformio.org/page/boards/raspberrypi/nanorp2040connect.html
PLATFORM: Raspberry Pi RP2040 (1.18.0) > Arduino Nano RP2040 Connect
HARDWARE: RP2040 133MHz, 264KB RAM, 2MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, raspberrypi-swd)
* framework-arduino-mbed @ 4.4.1
* tool-openocd-raspberrypi @ 2.1100.0 (11.0)
* tool-rp2040tools @ 1.0.2
* toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
  LDF: Library Dependency Finder → https://bit.ly/configure-pio-ldf
  LDF Modes: Finder \~ chain, Compatibility \~ soft
  Found 42 compatible libraries
  Scanning dependencies…
  Compiling .pio\\build\\nanorp2040connect\\src\\main.cpp.o
  Linking .pio\\build\\nanorp2040connect\\firmware.elf
  Generating UF2 image
  elf2uf2 “.pio\\build\\nanorp2040connect\\firmware.elf” “.pio\\build\\nanorp2040connect\\firmware.uf2”
  Checking size .pio\\build\\nanorp2040connect\\firmware.elf
  RAM:   \[==        \]  15.3% (used 41396 bytes from 270336 bytes)
  Flash: \[          \]   0.2% (used 4038 bytes from 2097152 bytes)
  Configuring upload protocol…
  AVAILABLE: cmsis-dap, jlink, picotool, raspberrypi-swd
  CURRENT: upload_protocol = picotool
  Looking for upload port…
  Auto-detected: COM3
  Forcing reset using 1200bps open/close on port COM3
  Uploading .pio\\build\\nanorp2040connect\\firmware.elf
  rp2040load 1.0.1 - compiled with go1.15.8
  \*\*\* \[upload\] Error 1
  ============================================================ \[FAILED\] Took 19.55 seconds ============================================================
* The terminal process “C:\\Users\\charl.platformio\\penv\\Scripts\\platformio.exe ‘run’, ‘–target’, ‘upload’” terminated with exit code: 1.
This is the error code I keep getting. This is my first time using PlatformIO so help would be much appreciated.
If you need any more info, ask and I will reply asap. Thanks
Are we talking Waveshare RP2040-Zero or Arduino Nano RP2040 Connect? Because you’ve selected the latter board.
For rp2040 load to be able to interact with the board, make sure you’ve used https://zadig.akeo.ie/ to load the correct drivers in BOOTSEL mode as shown here.
