Cannot upload or debug STM32 with ST-Link
platformio.ini:
platform = ststm32
board = genericSTM32F103C8
board_build.f_cpu = 36000000L
upload_protocol = stlink
debug_tool = stlink
I can connect to the target with “STM32 ST-Link Utility” when using hardware reset:
15:02:15 : ST-LINK SN : 56FF…
15:02:15 : V2J34S0
15:02:15 : Connected via SWD.
15:02:15 : SWD Frequency = 4,0 MHz.
15:02:15 : Connection mode : Connect Under Reset.
15:02:15 : Debug in Low Power mode enabled.
15:02:16 : Device ID:0x410
15:02:16 : Device flash Size : 128KBytes
15:02:16 : Device family :STM32F10xx Medium-density
But I cannot connect to it from PlatFormIO / VSCode / Windows 10.
Neither programming (flashing)
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
Error: init mode failed (unable to connect to the target)
in procedure 'program'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
nor debugging:
undefinedC:\Users\user\.platformio\packages\toolchain-gccarmnoneeabi\bin\arm-none-eabi-gdb.exe: warning: Couldn't determine a path for the index cache directory.
hla_swd
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 1000 kHz
Info : STLINK V2J34S0 (API v2) VID:PID 0483:3748
Info : Target voltage: 2.903616
Remote communication error. Target disconnected.: Success.
and
[Window Title]
Visual Studio Code
[Content]
Failed to launch GDB: .pioinit:13: Error in sourced command file:
Remote communication error. Target disconnected.: Success. (from interpreter-exec console “source .pioinit”)
[Open launch.json] [Cancel]
Versions:
Version: 1.50.1 (user setup)
Commit: d2e414d9e4239a252d1ab117bd7067f125afd80a
Date: 2020-10-13T15:06:15.712Z (3 wks ago)
Electron: 9.2.1
Chrome: 83.0.4103.122
Node.js: 12.14.1
V8: 8.3.110.13-electron.0
OS: Windows_NT x64 10.0.18363
You're up-to-date!
PlatformIO 5.0.2 is currently the newest version available.
PLATFORM: ST STM32 (8.1.0) > STM32F103C8 (20k RAM. 64k Flash)
HARDWARE: STM32F103C8T6 36MHz, 20KB RAM, 64KB Flash
DEBUG: Current (stlink) External (blackmagic, jlink, stlink)
 - framework-arduinoststm32 4.10900.200819 (1.9.0)
 - framework-cmsis 2.50501.200527 (5.5.1)
 - toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Does PIO connect using hardware reset? If not, how can it be enabled?
What does the wiring between the ST-Link and your MCU look like? Are you using a 10-pin connector with all 10 wires connected, or are you using a setup with 4 pins only? How do you power your board – through the ST-Link or with a separate power supply (e.g. via USB connection to board)?
Sorry.
Using the onboard ST-Link of the f407 discovery board with 5 wires.
The target is powered independently - measures 3.3 V.
Setup has not changed or even moved between using ST-Link Utility and VSCode/PIO.
Just to better understand: You are using the ST-Link of a STM32F4 Discovery board to connect to a STM32F1 chip on another board, right?
Which five wires have you connected? Does it include NRST?
Do you use the SWDIO and SWDCLK for other things than just ST-Link connection?
For your configuration, the OpenOCD command line looks like:
openocd -d2
    -s C:/Users/user/.platformio/packages/tool-openocde/scripts
    -f interface/stlink.cfg
    -c "transport select hla_swd"
    -f target/stm32f1x.cfg
    -c "program {.pio/build/genericSTM32F103C8/firmware.elf} verify reset; shutdown"
(with additional line breaks)
You can try to modify the scripts interface/stlink.cfg and target/stm32f1x.cfg to achieve the same reset/connect behavior.
The default settings seem to be:
cortex_m reset_config sysresetreq
reset_config srst_nogate
I’m unsure which configuration would correspond to “hardware reset”. In the past, I was successful using reset_config none separate. But it might be different in your case. Some documentation is here:
Additional documentation is here:
Thanks for your help.
Correct.
Connections as per https://www.st.com/resource/en/user_manual/dm00039084-discovery-kit-with-stm32f407vg-mcu-stmicroelectronics.pdf p. 17. including NRST.
IO and CLK are not connected to anything.
Your command for flashing works fine when run from .platformio\packages\tool-openocd\bin> with an absolute path for the .elf.
.platformio\packages\tool-openocd\scripts\interface\stlink.cfg only contains
adapter driver hla
hla_layout stlink
hla_device_desc "ST-LINK"
hla_vid_pid 0x0483 0x3744 0x0483 0x3748 0x0483 0x374b 0x0483 0x374d 0x0483 0x374e 0x0483 0x374f 0x0483 0x3752 0x0483 0x3753
but .platformio\packages\tool-openocd\scripts\target\stm32f1x.cfg has about 90 lines.
I have previously tried reset_config srst_only without success.
How can I increase the verbosity level for OpenOCD when run by PIO?
When I set debug_level 3 in .platformio\packages\tool-openocd\scripts\target\stm32f1x.cfg, PIO does not handle the output which seems to time out with
Debug: 113 10032 command.c:352 register_command_handler(): registering 'stm32f1x.cpu'...
I’ll try this on a blue-pill
Strange.
Another way to set the debug level of OpenOCD is described here:
Changing \.platformio\platforms\ststm32\builder\main.py:274 to
elif upload_protocol in debug_tools:
    openocd_args = [
        # "-d%d" % (2 if int(ARGUMENTS.get("PIOVERBOSE", 0)) else 1)
        "-d3"
also sets the debuglevel higher.
I can flash / debug a "bluepil"l much more reliably.
So I’ll recheck my wiring and hardware. Maybe the controller has an issue as well.
Seems to have been an issue with the wires. Different, shorter wires appear to have resolved the problem.
Embarrassing, and such a waste of time. Thanks again for your help!
