Hello. I have downloaded platformio extension for ESP32 and have weird issue trying to upload code to my ESP32 device. My esp32 device is on COM 11. I can easily program it on Arduino IDE without issues.
However, on the vscode, I am able to build the project, but I have problems uploading. It complains with the error message:
> Executing task: C:\Users\Lukas\.platformio\penv\Scripts\platformio.exe run --target upload <
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (1.11.1) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 2.10004.191002 (1.0.4)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 26 compatible libraries
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.7% (used 15436 bytes from 327680 bytes)
Flash: [== ] 16.5% (used 216635 bytes from 1310720 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Error: Please specify `upload_port` for environment or use global `--upload-port` option.
For some development platforms it can be a USB flash drive (i.e. /media/<user>/<device name>)
*** [upload] Explicit exit, status 1
============================================================================================== [FAILED] Took 1.54 seconds ==============================================================================================The terminal process "C:\Users\Lukas\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
My platformio.ini file contains :
upload_port = COM[11]
