Hi!
I’m trying to use Unity for unit testing using unity_fixture.h which is supposed to be in the “extras” folder of Unity.
Interestingly, after specifying Unity@2.5.2 in my platformio.ini, the folder contents of libdeps/Unity differ greatly from what I can see on git and it does not contain the extras folder at all.
Replacing the library version specification with lib_deps = https://github.com/ThrowTheSwitch/Unity.git
does have an effect: it creates a seemingly correct clone of the repository.
However, it still does not work (“does not work” as in pio test fails because “unity_fixture.h” is not found.
I suspect this is because there is another Unity folder in the libdeps folder still containing the wrong version (the one without the extras folder). Keeps regenerating, probably upon the “test_framework = unity” setting, which cannot be avoided.
From here on, I’m lost.
- How can the folder contents differ from the one on git despite the matching version numbers?
- If this mismatch is expected behaviour, how can I specify the exact git version so I could use the extras? How do I keep PlatformIO from installing and using version 2.5.2 automatically?
Any useful hints would be greatly appreciated.
