Cannot run remote unit tests from a github action : python setup.py egg_info did not run successfully
Hi, according to your article, I am trying to get remote unit testing (on target HW) to work triggered from a github action. I am not sure what is the most up-to-date yaml file to achieve this, but I am using this one
name: Unit Tests Remote Target
on: [push, pull_request]
jobs:
  UnitTests:
    runs-on: ubuntu-latest
    steps:
    - uses: actions/checkout@v2
    - name: Cache pip
      uses: actions/cache@v2
      with:
        path: ~/.cache/pip
        key: ${{ runner.os }}-pip-${{ hashFiles('**/requirements.txt') }}
        restore-keys: |
    - name: Cache PlatformIO
      with:
        path: ~/.platformio
        key: ${{ runner.os }}-${{ hashFiles('**/lockfiles') }}
    - name: Set up Python
      uses: actions/setup-python@v2
    - name: Install PlatformIO
      run: |
        python -m pip install --upgrade pip
        pip install --upgrade platformio
    - name: Run remote tests on the target platform
      run: platformio remote test -e esp32
An error occurs in the last step (Run remote tests on the target platform). This is the output from github action:
  shell: /usr/bin/bash -e {0}
  env:
    pythonLocation: /opt/hostedtoolcache/Python/3.10.2/x64
    LD_LIBRARY_PATH: /opt/hostedtoolcache/Python/3.10.2/x64/lib
If you like PlatformIO, please:
- follow us on Twitter to stay up-to-date on the latest project news > https://twitter.com/PlatformIO_Org
- star it on GitHub > https://github.com/platformio/platformio
- try PlatformIO IDE for embedded development > https://platformio.org/platformio-ide
Tool Manager: Installing platformio/contrib-pysite @ ~2.310.0
Collecting twisted==21.7.0
  Downloading Twisted-21.7.0.tar.gz (3.7 MB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.7/3.7 MB 66.5 MB/s eta 0:00:00
  Installing build dependencies: started
  Installing build dependencies: finished with status 'done'
  Getting requirements to build wheel: started
  Getting requirements to build wheel: finished with status 'done'
  Preparing metadata (pyproject.toml): started
  Preparing metadata (pyproject.toml): finished with status 'done'
Collecting cryptography<35.0.0,>=3.3
  Downloading cryptography-3.4.8.tar.gz (546 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 546.9/546.9 KB 84.3 MB/s eta 0:00:00
  Installing build dependencies: still running...
Collecting pyopenssl<=21.0.0,>=16.0.0
  Downloading pyOpenSSL-21.0.0.tar.gz (175 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 175.7/175.7 KB 31.0 MB/s eta 0:00:00
Collecting service_identity<=21.1.0,>=18.1.0
  Downloading service-identity-21.1.0.tar.gz (40 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 40.1/40.1 KB 13.1 MB/s eta 0:00:00
Collecting Automat>=0.8.0
  Downloading Automat-20.2.0.tar.gz (61 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.7/61.7 KB 22.2 MB/s eta 0:00:00
  Preparing metadata (setup.py): started
  Preparing metadata (setup.py): finished with status 'error'
  error: subprocess-exited-with-error
  Γ— python setup.py egg_info did not run successfully.
  β”‚ exit code: 1
  ╰─> [53 lines of output]
      WARNING: The wheel package is not available.
        Γ— python setup.py bdist_wheel did not run successfully.
        β”‚ exit code: 1
        ╰─> [6 lines of output]
            usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
               or: setup.py --help [cmd1 cmd2 ...]
               or: setup.py --help-commands
               or: setup.py cmd --help
            error: invalid command 'bdist_wheel'
            [end of output]
        note: This error originates from a subprocess, and is likely not a problem with pip.
        ERROR: Failed building wheel for m2r
      ERROR: Failed to build one or more wheels
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/setuptools/installer.py", line 75, in fetch_build_egg
          subprocess.check_call(cmd)
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/subprocess.py", line 369, in check_call
          raise CalledProcessError(retcode, cmd)
      subprocess.CalledProcessError: Command '['/opt/hostedtoolcache/Python/3.10.2/x64/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpsnb5q4xo', '--quiet', 'm2r']' returned non-zero exit status 1.
      The above exception was the direct cause of the following exception:
        File "<string>", line 2, in <module>
        File "<pip-setuptools-caller>", line 34, in <module>
        File "/tmp/pip-install-cufod7go/automat_97fa58c15650405e9db4e6bc10f2d4b1/setup.py", line 15, in <module>
          setup(
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/setuptools/__init__.py", line 152, in setup
          _install_setup_requires(attrs)
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/setuptools/__init__.py", line 147, in _install_setup_requires
          dist.fetch_build_eggs(dist.setup_requires)
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/setuptools/dist.py", line 806, in fetch_build_eggs
          resolved_dists = pkg_resources.working_set.resolve(
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/pkg_resources/__init__.py", line 766, in resolve
          dist = best[req.key] = env.best_match(
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/pkg_resources/__init__.py", line 1051, in best_match
          return self.obtain(req, installer)
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/pkg_resources/__init__.py", line 1063, in obtain
          return installer(requirement)
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/setuptools/dist.py", line 877, in fetch_build_egg
          return fetch_build_egg(self, req)
        File "/opt/hostedtoolcache/Python/3.10.2/x64/lib/python3.10/site-packages/setuptools/installer.py", line 77, in fetch_build_egg
          raise DistutilsError(str(e)) from e
      distutils.errors.DistutilsError: Command '['/opt/hostedtoolcache/Python/3.10.2/x64/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpsnb5q4xo', '--quiet', 'm2r']' returned non-zero exit status 1.
      !!! m2r not found, long_description is bad, don't upload this to PyPI !!!
      [end of output]
error: metadata-generation-failed
Γ— Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Error:
Please ensure that the next packages are installed:
sudo apt install python3-dev libffi-dev libssl-dev
Error: Process completed with exit code 1.
Any hints on how to solve this ?
  • Remote testing (on this repo) from a platformio terminal works fine,
  • Native Unit tests from github actions (eg Strooom/logging repo) also work fine, (the .yaml file is simpler here)
CC @ivankravets when using the PIO-tutorial supplied YAML, pip seems to fail at the installation of markdown-to-reStructure pacakge.
Could you replace these lines with
Does it work?
No,
this time Python 3.9.10 gets installed instead of 3.10.2 but the error I get looks exactly the same
(first part of log skipped)
  β”‚ exit code: 1
        β”‚ exit code: 1
            [end of output]
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/setuptools/installer.py", line 75, in fetch_build_egg
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/subprocess.py", line 373, in check_call
      subprocess.CalledProcessError: Command '['/opt/hostedtoolcache/Python/3.9.10/x64/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpbj0gv7zt', '--quiet', 'm2r']' returned non-zero exit status 1.
        File "/tmp/pip-install-tdv149w6/automat_5dc667c970804842bec033f63e724f94/setup.py", line 15, in <module>
          setup(
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/setuptools/__init__.py", line 152, in setup
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/setuptools/__init__.py", line 147, in _install_setup_requires
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/setuptools/dist.py", line 806, in fetch_build_eggs
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/pkg_resources/__init__.py", line 766, in resolve
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/pkg_resources/__init__.py", line 1051, in best_match
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/pkg_resources/__init__.py", line 1063, in obtain
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/setuptools/dist.py", line 877, in fetch_build_egg
        File "/opt/hostedtoolcache/Python/3.9.10/x64/lib/python3.9/site-packages/setuptools/installer.py", line 77, in fetch_build_egg
      distutils.errors.DistutilsError: Command '['/opt/hostedtoolcache/Python/3.9.10/x64/bin/python', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpbj0gv7zt', '--quiet', 'm2r']' returned non-zero exit status 1.
      [end of output]
Error:
Could you restart your CI? We deployed new packages of
Hi Ivan,
looks like PIO is now installing properly and running fine in the github-action-runner. :slight_smile:
I now hit this error
Error: -23 12:02:33 [error] You are not authorized! Please log in to PlatformIO Account.
Github actions has evolved a bit since your tutorial has been published. They now have several sections on Secrets… I put the PLATFORMIO_AUTH_TOKEN in
Settings
  Secrets
    Actions
      Repository secrets
Where is PIO expecting this secret ?
This definitely looks like the right envrionment variable to me.
Is there some code you added to copy this repository secret into this environment variable?
no, maybe I missed something in the tutorial. I thought that copying the token from the remote platformio setup to the repo secret was enough to make it work… Can you point me to an example, or a .yml file which is set up for remote testing from a github action ?
This piece of code seems to bridge the gap between the secret value and putting it into the environment variables.
