I have Windows 10, just installed Visual Studio Code. Now I’m trying to install the PlatformIO IDE extension, but it is failing.
After selecting it from the list of extensions and clicking the install button, it goes through several minutes of stuff, then tells me it is installed, reboot the window. So I click on the link to do that, and get:
console.ts:137 [Extension Host] Error: Error: Traceback (most recent call last):
File "c:\users\ralph\.platformio\penv\lib\site-packages\platformio\__main__.py", line 102, in main
File "c:\users\ralph\.platformio\penv\lib\site-packages\click\core.py", line 764, in __call__
File "c:\users\ralph\.platformio\penv\lib\site-packages\click\core.py", line 717, in main
rv = self.invoke(ctx)
File "c:\users\ralph\.platformio\penv\lib\site-packages\platformio\commands\__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "c:\users\ralph\.platformio\penv\lib\site-packages\click\core.py", line 1137, in invoke
File "c:\users\ralph\.platformio\penv\lib\site-packages\click\core.py", line 956, in invoke
File "c:\users\ralph\.platformio\penv\lib\site-packages\click\core.py", line 555, in invoke
return callback(*args, **kwargs)
File "c:\users\ralph\.platformio\penv\lib\site-packages\platformio\commands\home\command.py", line 51, in cli
inject_contrib_pysite()
File "c:\users\ralph\.platformio\penv\lib\site-packages\platformio\managers\core.py", line 111, in inject_contrib_pysite
addsitedir(contrib_pysite_dir)
File "c:\users\ralph\.platformio\penv\lib\site.py", line 202, in addsitedir
addpackage(sitedir, name, known_paths)
File "c:\users\ralph\.platformio\penv\lib\site.py", line 170, in addpackage
exec(line)
File "<string>", line 1, in <module>
AttributeError: module 'os' has no attribute 'add_dll_directory'
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
I have search for the “module ‘os’ has no attribute ‘add_dll_directory’” error with no results.
I see there are other installation options; my current project needs me to work on VS Code with the PlatformIO IDE extension. Can I run an external install program and achieve that? Or is there something else I can do to try to solve this?
I have python 3.8.0a1, Windows 10 Pro 10.0.18362 Build 18362. The python was evidently built by one of the installs (VS Code or PlatformIO) I did recently, I didn’t have it before.
Can anyone point me to anything here?
