Hello guys, I am new to the community and I am trying to set everything up according to the tutorial I am using. He seems to set up everything smoothly but for me, it doesn’t work.
Every time I try to install it says this:
Installing “platformio-ide-terminal@2.10.0” failed.Hide output…
> node-pty-prebuilt-multiarch@0.9.0-beta21.legacy install C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch
> prebuild-install || node scripts/install.js
C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch>if not defined npm_config_node_gyp (node "C:\Users\Benji\AppData\Local\atom\app-1.52.0\resources\app\apm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Users\Benji\AppData\Local\atom\app-1.52.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
Building the projects in this solution one at a time. To enable parallel build, please add the "-m" switch.
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppBuild.targets(499,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty.vcxproj]
conpty.cc
path_util.cc
win_delay_load_hook.cc
C:\Users\Benji\AppData\Local\node-gyp\Cache\6.1.12\include\node\v8.h(8205,1): warning C4996: 'v8::MicrotasksCompletedCallback': was declared deprecated (compiling source file ..\src\win\path_util.cc) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty.vcxproj]
C:\Users\Benji\AppData\Local\node-gyp\Cache\6.1.12\include\node\v8.h(8214,1): warning C4996: 'v8::MicrotasksCompletedCallback': was declared deprecated (compiling source file ..\src\win\path_util.cc) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty.vcxproj]
C:\Users\Benji\AppData\Local\node-gyp\Cache\6.1.12\include\node\v8.h(8205,1): warning C4996: 'v8::MicrotasksCompletedCallback': was declared deprecated (compiling source file ..\src\win\conpty.cc) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty.vcxproj]
C:\Users\Benji\AppData\Local\node-gyp\Cache\6.1.12\include\node\v8.h(8214,1): warning C4996: 'v8::MicrotasksCompletedCallback': was declared deprecated (compiling source file ..\src\win\conpty.cc) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty.vcxproj]
Creating library C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\conpty.lib and object C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\conpty.exp
Generating code
Previous IPDB not found, fall back to full compilation.
All 951 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
Finished generating code
conpty.vcxproj -> C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\\conpty.node
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppBuild.targets(499,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty_console_list.vcxproj]
conpty_console_list.cc
C:\Users\Benji\AppData\Local\node-gyp\Cache\6.1.12\include\node\v8.h(8205,1): warning C4996: 'v8::MicrotasksCompletedCallback': was declared deprecated (compiling source file ..\src\win\conpty_console_list.cc) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty_console_list.vcxproj]
C:\Users\Benji\AppData\Local\node-gyp\Cache\6.1.12\include\node\v8.h(8214,1): warning C4996: 'v8::MicrotasksCompletedCallback': was declared deprecated (compiling source file ..\src\win\conpty_console_list.cc) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\conpty_console_list.vcxproj]
Creating library C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\conpty_console_list.lib and object C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\conpty_console_list.exp
Generating code
All 167 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
conpty_console_list.vcxproj -> C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\\conpty_console_list.node
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppBuild.targets(499,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty.vcxproj]
AgentLocation.cc
winpty.cc
BackgroundDesktop.cc
Buffer.cc
DebugClient.cc
GenRandom.cc
OwnedHandle.cc
StringUtil.cc
WindowsSecurity.cc
WindowsVersion.cc
WinptyAssert.cc
WinptyException.cc
WinptyVersion.cc
Creating library C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\winpty.lib and object C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\winpty.exp
Generating code
All 1034 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
winpty.vcxproj -> C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\Release\\winpty.dll
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppBuild.targets(499,5): warning MSB8029: The Intermediate directory or Output directory cannot reside under the Temporary directory as it could lead to issues with incremental build. [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
Agent.cc
AgentCreateDesktop.cc
ConsoleFont.cc
ConsoleInput.cc
ConsoleInputReencoding.cc
ConsoleLine.cc
DebugShowInput.cc
DefaultInputMap.cc
EventLoop.cc
InputMap.cc
LargeConsoleRead.cc
NamedPipe.cc
Scraper.cc
Terminal.cc
Win32Console.cc
Win32ConsoleBuffer.cc
main.cc
Buffer.cc
DebugClient.cc
GenRandom.cc
OwnedHandle.cc
StringUtil.cc
WindowsSecurity.cc
WindowsVersion.cc
WinptyAssert.cc
WinptyException.cc
WinptyVersion.cc
Generating code
C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\deps\winpty\src\agent\Agent.cc(231): warning C4722: 'Agent::~Agent': destructor never returns, potential memory leak [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
All 1725 functions were compiled because no usable IPDB/IOBJ from previous compilation was found.
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: The specified task executable "link.exe" could not be run. System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\Release\obj\winpty-agent\winpty-agent.tlog'. [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at System.IO.FileSystemEnumerableIterator`1.CommonInit() [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at System.IO.Directory.GetFiles(String path, String searchPattern) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at Microsoft.Build.Utilities.TrackedDependencies.ExpandWildcards(ITaskItem[] expand) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at Microsoft.Build.Utilities.CanonicalTrackedOutputFiles.InternalConstruct(ITask ownerTask, ITaskItem[] tlogFiles, Boolean constructOutputsFromTLogs) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at Microsoft.Build.CPPTasks.TrackedVCToolTask.PostExecuteTool(Int32 exitCode) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at Microsoft.Build.CPPTasks.TrackedVCToolTask.ExecuteTool(String pathToTool, String responseFileCommands, String commandLineCommands) [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(876,5): error MSB6003: at Microsoft.Build.Utilities.ToolTask.Execute() [C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch\build\deps\winpty\src\winpty-agent.vcxproj]
prebuild-install WARN install No prebuilt binaries found (target=6.1.12 runtime=electron arch=x64 libc= platform=win32)
gyp ERR! build error
gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Current\Bin\MSBuild.exe` failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Users\Benji\AppData\Local\atom\app-1.52.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:200:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
gyp ERR! System Windows_NT 10.0.18363
gyp ERR! command "C:\\Users\\Benji\\AppData\\Local\\atom\\app-1.52.0\\resources\\app\\apm\\bin\\node.exe" "C:\\Users\\Benji\\AppData\\Local\\atom\\app-1.52.0\\resources\\app\\apm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\node_modules\platformio-ide-terminal\node_modules\node-pty-prebuilt-multiarch
gyp ERR! node -v v12.4.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Benji\AppData\Local\Temp\apm-install-dir-2020919-7220-19pxwn9.791d\package.json'
npm WARN apm-install-dir-2020919-7220-19pxwn9.791d No description
npm WARN apm-install-dir-2020919-7220-19pxwn9.791d No repository field.
npm WARN apm-install-dir-2020919-7220-19pxwn9.791d No README data
npm WARN apm-install-dir-2020919-7220-19pxwn9.791d No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-pty-prebuilt-multiarch@0.9.0-beta21.legacy install: `prebuild-install || node scripts/install.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-pty-prebuilt-multiarch@0.9.0-beta21.legacy install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\Benji\.atom\.apm\_logs\2020-10-19T17_44_42_784Z-debug.log
Thank you in advance.
Ben
