I am working on a project and I’ve ran into a “weird” problem trying to follow the tutorial at https://docs.platformio.org/en/latest/advanced/unit-testing/frameworks/custom/runner.html.
Every time I try to run the tests, I get
UserSideException: Could not find custom test runner by this path -> <path_to_file>/test_custom_runner.py
where <path_to_file>
is the actual path to file that exists. I’ve triple-checked, placed it in different locations of the test hierarchy, the file exists and can be opened in editor if I follow the link in VSCode terminal. I get the exact same error when trying the same from a command line.
My setup is a multi-environment ESP32 project, where the “default” ESP32 environment runs on-chip C++ tests without a problem (other than occasional error in the test or code under test, that is) and I’ve created a second project environment, native
platform, with the hope that I could run python pytest tests against the device (the device, among other things, communicates SCPI via serial, so I could use PyVisa to check if I get the expected values and responses). The computer environment is a Fedora 38 (Linux) with Python 3.11 and PlatformIO 6.1.11.
So far I’ve managed to track my problem down to platformio-core/platformio/test/runners/factory.py
where the exception is raised (it’s either FileNotFoundError
(unlikely) or an ImportError
if load_python_module
method from platformio-core/platformio/compat.py
does not succeed).
Before trying to debug the situation further, I thought I’d better ask if there’s something obvious I’m doing wrong, anybody has any experience with this kind of setup or if there’s a better way to do the thing I want to do - running tests other than C/C++ (pytest) against the device from within Platformio?
