Hi
I have a B-L475E-IOT01A board. Previously, I have tried the Arduino framework. Now, I tried to learn the framework of mbed with plateformio.
I tried to import the library provided by st for mbed library. However, I cannot find the mbed BSP_B-L475E-IOT01, even though I can find it here.
I wonder what is the reason for the above problem and what is the correct solution?
Thanks in advance.
Good question, not sure why it’s not listed. (CC @ivankravets).
You should be able to download the library manually (https://os.mbed.com/teams/ST/code/BSP_B-L475E-IOT01//archive/bfe8272ced90.zip) and add a library.json that specifies the special mbed builder as needed, like in that library.
"authors": {
"name": "Afdhal Atiff Tan",
"url": "https://os.mbed.com/users/AfdhalAtiffTan/"
"build": {
"builder": "MbedLibBuilder"
"description": "This library meant to allow mbed boards (tested on F401RE) to act as modbus slave. I don't own this work, I just made some simple modifications so that it runs on mbed. My modification were labeled with \"afdhal\".Summary: Modified modbus Arduino library for mbed. See readme for more details.Feel free to use it as you want.Special thanks to the original authors.",
"examples": [
"https://os.mbed.com/users/AfdhalAtiffTan/code/ModbusRTU-RS232/",
"https://os.mbed.com/users/AfdhalAtiffTan/code/FoodComputerARM-alpha/"
"frameworks": "mbed",
"keywords": [
"arduino",
"millis",
"modbus",
"modserial",
"rtu"
"name": "ModbusSlave232",
"platforms": "*",
"repository": {
"type": "hg",
"url": "https://os.mbed.com/users/AfdhalAtiffTan/code/ModbusSlave232/"
"version": "0.0.0+sha.5318159b5eab"
