I am using a custom board (i have divided memory into high and low, each one is defined as a board) but when i build it does not find the linker script
The .json file:
"build": {
"core": "arduino",
"cpu": "cortex-m3",
"extra_flags": "-D__SAM3X8E__ -DARDUINO_ARCH_SAM -DARDUINO_SAM_DUE",
"f_cpu": "84000000L",
"hwids": [
"0x2341",
"0x003E"
"0x2341",
"0x003D"
"0x2A03",
"0x003D"
"ldscript": "flash_low.ld",
"mcu": "at91sam3x8e",
"usb_product": "Arduino Due",
"variant": "arduino_due_x"
"connectivity": [
"can"
"debug": {
"jlink_device": "ATSAM3X8E",
"openocd_chipname": "at91sam3X8E",
"openocd_target": "at91sam3XXX",
"svd_path": "ATSAM3X8E.svd"
"frameworks": [
"arduino",
"simba"
"name": "Arduino Due (Low Bootloader)",
"upload": {
"disable_flushing": true,
"maximum_ram_size": 98304,
"maximum_size": 524288,
"native_usb": false,
"protocol": "sam-ba",
"protocols": [
"sam-ba",
"jlink",
"blackmagic",
"atmel-ice",
"stlink"
"require_upload_port": true,
"use_1200bps_touch": true,
"wait_for_upload_port": false
"url": "https://www.arduino.cc/en/Main/ArduinoBoardDue",
"vendor": "Arduino"
I added the board to the .platformio/packages/framework-arduino-same/boards.txt file:
arduino_due_xhb.name=Arduino Due (Low bootloader)
arduino_due_xhb.vid.0=0x2341
arduino_due_xhb.pid.0=0x003e
arduino_due_xhb.vid.1=0x2A03
arduino_due_xhb.pid.1=0x003e
arduino_due_xhb.upload.tool=bossac
arduino_due_xhb.upload.protocol=sam-ba
arduino_due_xhb.upload.maximum_size=262144
arduino_due_xhb.upload.use_1200bps_touch=true_xhb.upload.tool=bossac
arduino_due_xhb.upload.wait_for_upload_port=true
arduino_due_xhb.upload.native_usb=true
arduino_due_xhb.build.mcu=cortex-m3
arduino_due_xhb.build.f_cpu=84000000L
arduino_due_xhb.build.usb_manufacturer="Arduino LLC"
arduino_due_xhb.build.usb_product="Arduino Due"
arduino_due_xhb.build.board=SAM_DUE
arduino_due_xhb.build.core=arduino
arduino_due_xhb.build.extra_flags=-D__SAM3X8E__ -mthumb {build.usb_flags}
arduino_due_xhb.build.ldscript=linker_scripts/gcc/flash_low.ld
arduino_due_xhb.build.variant=arduino_due_x
arduino_due_xhb.build.variant_system_lib=libsam_sam3x8e_gcc_rel.a
arduino_due_xhb.build.vid=0x2341
arduino_due_xhb.build.pid=0x003e
Made the necessary modifications and copied flash_low.ld
to ~/.platformio/packages/framework-arduinosam/variants/arduino_due_x/linker_scripts/gcc
Where could it be looking for the ld script?
