Using Platformio ide is impossible to debug the STM32 NUCLEO-H745ZI-Q. The code I’m trying to upload/debug is a simple led blinking Zephyr sample code, directly gotten from the Platformio samples library. I’m on Windows10
This is the platformio.ini
[env:nucleo_h745zi_q]
platform = ststm32
board = nucleo_h745zi_q
framework = zephyr
upload_protocol = stlink
debug_tool = stlink
And this is the console output that I’m getting:
xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2021-10-16-21:19)
Licensed under GNU GPL v2
For bug reports, read
Info : tcl server disabled
Info : telnet server disabled
Info : STLINK V3J2M1 (API v3) VID:PID 0483:374E
Info : Target voltage: 3.277815
Info : Unable to match requested speed 1800 kHz, using 1000 kHz
Info : clock speed 1000 kHz
Info : stlink_dap_op_connect(connect)
Info : SWD DPIDR 0x6ba02477
Info : stm32h7x.cpu0: Cortex-M7 r1p1 processor detected
Info : stm32h7x.cpu0: target has 8 breakpoints, 4 watchpoints
Info : stm32h7x.cpu1: Cortex-M4 r0p1 processor detected
Info : stm32h7x.cpu1: target has 6 breakpoints, 4 watchpoints
Error: stm32h7x.cpu1 – clearing lockup after double fault
Polling target stm32h7x.cpu1 failed, trying to reexamine
Info : gdb port disabled
Info : starting gdb server for stm32h7x.cpu0 on pipe
Info : starting gdb server for stm32h7x.cpu1 on pipe
Info : accepting ‘gdb’ connection from pipe
Info : Device: STM32H74x/75x
Info : flash size probed value 2048
Info : STM32H7 flash has dual banks
Info : Bank (0) size is 1024 kb, base address is 0x08000000
Info : Bank (1) size is 1024 kb, base address is 0x08100000
Info : New GDB Connection: 1, Target stm32h7x.cpu0, state: halted
Error: Failed to read memory at 0x1ff1e882
Info : Bank (2) size is 1024 kb, base address is 0x08000000
Info : Bank (3) size is 1024 kb, base address is 0x08100000
Info : New GDB Connection: 2, Target stm32h7x.cpu1, state: halted
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1010 ms). Workaround: increase “set remotetimeout” in GDB
Error: GDB missing ack(2) - assumed good
Error: Failed to read memory at 0xfffff000
0xfffffffe in ?? ()
xPSR: 0x01000000 pc: 0x08001030 msp: 0x24000700
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
Info : Unable to match requested speed 4000 kHz, using 3300 kHz
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1013 ms). Workaround: increase “set remotetimeout” in GDB
Loading section rom_start, size 0x298 lma 0x8000000
Loading section text, size 0x32d2 lma 0x8000298
Loading section .ARM.exidx, size 0x8 lma 0x800356c
Loading section initlevel, size 0x98 lma 0x8003574
Loading section devices, size 0x168 lma 0x800360c
Loading section sw_isr_table, size 0x4b0 lma 0x8003774
Loading section device_handles, size 0x78 lma 0x8003c24
Loading section rodata, size 0x318 lma 0x8003c9c
Loading section datas, size 0x30 lma 0x8003fb4
Loading section device_states, size 0x3c lma 0x8003fe4
Info : Padding image section 0 at 0x0800356a with 2 bytes
xPSR: 0x01000000 pc: 0x08001038 msp: 0x24000700
Start address 0x8001038, load size 16414
Transfer rate: 5 KB/sec, 1641 bytes/write.
Warn : negative reply, retrying
Then the debugger hangs indefinitely.
It is worth noting that when using the older NUCLEO-F401RE everything works fine.
Thanks in advance.
