When I try to debug my esp32-ethernet-kit v1.2 board through PlatformIO on VSCode, I will get errror messages like “.pioinit:13: Error in sourced command file: Remote communication error. Target disconnected.: Success.”
I tried to execute the following command:
C:\Users\rui\.platformio\packages\tool-openocd-esp32>bin\openocd.exe -s C:\Users\rui\.platformio\packages\tool-openocd-esp32\share\openocd\scripts -f interface\ftdi\esp32_devkitj_v1.cfg -f board\esp32-wrover.cfg
And here is the result message
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x400E6552 (active) APP_CPU: PC=0x401B67A6
Error: libusb_handle_events() failed with LIBUSB_ERROR_IO
Error: unable to purge ftdi rx buffers: LIBUSB_ERROR_IO
Error: error while flushing MPSSE queue: -4
Polling target esp32 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Examination failed, GDB will be halted. Polling again in 1500ms
Examination failed, GDB will be halted. Polling again in 3100ms
Below is my previous post, in which the errors are different from what I’m getting now.
Anyone have an idea of what’s going on? Thanks
