Dear colleagues,
after working a while with the ESP32 arduino framework I like to switch for some application to the espidf framework.
But the first attempt created a lot of compile errors caused by problems within the framework.
Especially I was puzzled by looking into “transport_ws.c”: I had assumed, that this file is copied from the library structure into the build directory of the project.
But the file “transport_ws.c” in the “.platformio” structure is completely different with the version in the project build dir, which is also wrong and causes errors.
BTW: the projects goal is simply to compile the example included in the MQTT library from Andrey Mitrokhin.
I hope somebody has a clue whats going wrong here, as this should be a very primitive setup.
Thanks in advance,
Regards Thomas
PS: I’ve tested on Windows 10 and Debian 10 Linux
the platformio.ini file:
[env:nodemcu-32s]
#platform = https://github.com/platformio/platform-espressif32.git
#platform_packages = framework-espidf @ https://github.com/espressif/esp-idf.git
board = nodemcu-32s
framework = espidf
board_build.mcu = esp32
monitor_port = COM7
upload_port = COM7
#build_flags = -w
# Using a library name
MQTT library for ESP32 (ESP-IDF)
# ... or using library Id
5670
# ... or depend on a specific version
MQTT library for ESP32 (ESP-IDF)@1.0.0
# Semantic Versioning Rules
# http://docs.platformio.org/page/userguide/lib/cmd_install.html#description
MQTT library for ESP32 (ESP-IDF)@^1.0.0
MQTT library for ESP32 (ESP-IDF)@~1.0.0
MQTT library for ESP32 (ESP-IDF)@>=1.0.0
the espidf version:
espressif32 @ 1.12.4
Updating toolchain-xtensa32 @ 2.50200.80
the error messages:
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/http_parser.o
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/http_parser.c: In function 'http_parser_execute':
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/http_parser.c:1816:31: warning: this statement may fall through [-Wimplicit-fallthrough=]
parser->upgrade = 1;
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/http_parser.c:1818:13: note: here
case 1:
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/http_parser.c: In function 'http_parser_parse_url':
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/http_parser.c:2375:18: warning: this statement may fall through [-Wimplicit-fallthrough=]
found_at = 1;
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/http_parser.c:2378:7: note: here
case s_req_server:
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/mqtt_client.o
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/mqtt_msg.o
Archiving .pio/build/nodemcu-32s/bootloader/esp-idf/xtensa/libxtensa.a
Linking .pio/build/nodemcu-32s/bootloader.elf
In file included from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/include/platform_esp32_idf.h:21,
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/include/platform.h:11,
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/mqtt_client.c:2:
/home/thomas/.platformio/packages/framework-espidf/components/esp32/include/rom/queue.h:1:2: warning: #warning rom/queue.h is deprecated, please use sys/queue.h instead [-Wcpp]
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/mqtt_msg.c:35:
Building .pio/build/nodemcu-32s/bootloader.bin
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/mqtt_outbox.o
esptool.py v2.6
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/platform_esp32_idf.o
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/include/mqtt_outbox.h:8,
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/mqtt_outbox.c:1:
In file included from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/mqtt_outbox.c:4:
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/platform_esp32_idf.c:1:
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/transport.o
In file included from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport.c:4:
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/transport_ssl.o
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/transport_tcp.o
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport.c:8:
Compiling .pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/transport_ws.o
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport_tcp.c:12:
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport_ssl.c:24:
from .pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport_ws.c:5:
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport_ws.c: In function 'ws_connect':
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport_ws.c:100:53: error: '258EAFA5-E914-47DA-95CA-C5AB...' directive writing 36 bytes into a region of size between 33 and 64 [-Werror=format-overflow=]
int key_len = sprintf((char*)client_key_b64, "%s258EAFA5-E914-47DA-95CA-C5AB0DC85B11", (char*)client_key);
.pio/libdeps/nodemcu-32s/MQTT library for ESP32 _ESP-IDF__ID5670/src/transport_ws.c:100:19: note: 'sprintf' output between 37 and 68 bytes into a destination of size 64
cc1: some warnings being treated as errors
*** [.pio/build/nodemcu-32s/lib339/MQTT library for ESP32 _ESP-IDF__ID5670/transport_ws.o] Error 1``
