When I try to compile Bearssl for the esp8266 platform I get the following error:
/home/christian/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp: In function 'bool brssl::certificate_to_trust_anchor_inner(br_x509_trust_anchor*, const br_x509_certificate*)':
/home/christian/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp:115:73: error: too many arguments to function 'void br_x509_decoder_init(br_x509_decoder_context*, void (*)(void*, const void*, size_t), void*)'
br_x509_decoder_init(dc.get(), byte_vector_append, (void*)&vdn, 0, 0);
In file included from .piolibdeps/ArduinoBearSSL_ID5571/src/bearssl/bearssl_ssl.h:36:0,
from .piolibdeps/ArduinoBearSSL_ID5571/src/bearssl/bearssl.h:136,
from /home/christian/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp:25:
.piolibdeps/ArduinoBearSSL_ID5571/src/bearssl/bearssl_x509.h:987:6: note: declared here
void br_x509_decoder_init(br_x509_decoder_context *ctx,
Compiling .pioenvs/esp8266/lib75e/ESP8266WiFi/ESP8266WiFi.cpp.o
The BearSSLHelpers.cpp looks a bit strange to me on my systems _ have been replaced by spaces.
My platform.io ini looks like this:
[env:esp8266]
board = esp_wroom_02
upload_speed = 921600
upload_resetmethod = nodemcu
lib_deps = ArduinoBearSSL@1.3.0, ArduinoECCX08@1.3.2, SPI, Wire, ESP8266WiFi
upload_port = /dev/ttyUSB0
platform = espressif8266@2.0.1
build_flags = -D NDEBUG
-mtarget-align
-DCLIENT_VERSION=V024
-Wl,-Map,firmware.map
-Wl,-Teagle.flash.2m512.ld
-DPIO_FRAMEWORK_ARDUINO_LWIP2_HIGHER_BANDWIDTH_LOW_FLASH
-DVTABLES_IN_FLASH
-fno-exceptions
board_build.flash_mode = qio
build_unflags = -Wall
board_build.f_cpu = 80000000L
Has anybody seen something similar?
