Cannot build with latest framework-espidf @ 3.50100.0 (5.1.0)
I want to use the latest esp-idf release 3.50100.0 with platformio. However, I encounter issues. I already covered all options: fresh re-installed platformio including delete of .plarformio folder, updated packages, google, chatgpt, etc. However, error persists.
I see also a “not a git repository”. But that should not be the issue because previous version 3.50002.230601 is working without problems. I think is related to CMake Error kconfgen not able to create the sdkconfig.main file.
Any help is much appreciated.
My platformio.ini file:
[platformio]
default_envs = main
[env]
platform = espressif32@6.3.2                            ; see versions  https://registry.platformio.org/platforms/platformio/espressif32/versions
framework = espidf
platform_packages = framework-espidf@3.50100.0   ; previous 3.50002.230601 is working, see versions https://registry.platformio.org/tools/platformio/framework-espidf/versions
upload_speed = 921600
monitor_raw = true
The output when I try to buid is:
Processing main (platform: espressif32@6.3.2; board: esp32dev; framework: espidf)
------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (6.3.2) > Espressif ESP32 Dev Module
 - framework-espidf @ 3.50100.0 (5.1.0)
 - tool-cmake @ 3.16.4
 - tool-idf @ 1.0.1
 - tool-mconf @ 1.4060000.20190628 (406.0.0)
 - tool-ninja @ 1.9.0
 - toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
 - toolchain-xtensa-esp32 @ 11.2.0+2022r1
-- Building ESP-IDF components for target esp32
-- Project sdkconfig file C:/git/firmware/sdkconfig.main
-- Configuring incomplete, errors occurred!
See also "C:/git/firmware/.pio/build/main/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any of the parent directories): .git
C:\Users\EFeru\.platformio\penv\.espidf-5.1.0\Scripts\python.exe: No module named kconfgen
CMake Error at C:/Users/EFeru/.platformio/packages/framework-espidf/tools/cmake/kconfig.cmake:176 (message):
  Failed to run kconfgen
  (C:/Users/EFeru/.platformio/penv/.espidf-5.1.0/Scripts/python.exe;-m;kconfgen;--list-separator=semicolon;--kconfig;C:/Users/EFeru/.platformio/packages/framework-espidf/Kconfig;--sdkconfig-rename;C:/Users/EFeru/.platformio/packages/framework-espidf/sdkconfig.rename;--config;C:/git/firmware/sdkconfig.main;--env-file;C:/git/firmware/.pio/build/main/config.env).
  Error 1
  C:/Users/EFeru/.platformio/packages/framework-espidf/tools/cmake/build.cmake:611 (__kconfig_generate_config)
  C:/Users/EFeru/.platformio/packages/framework-espidf/tools/cmake/project.cmake:464 (idf_build_process)
  CMakeLists.txt:3 (project)
I think this is what kills it, there’s a mismatch between what python packets the @6.3.2 platform installs and what python pacakges ESP-IDF 5.1.0 needs.
Currently, the references package vesion for the bleeding edge is 5.1.0.
So I’d recomment to just
  1. Delete C:\Users\EFeru\.platformio\penv\.espidf-5.1.0\
  2. Use the platformio.ini
[platformio]
default_envs = main
[env]
platform = https://github.com/platformio/platform-espressif32.git#f1fdbc5838f6271379c89dd97242fb0614fdfdde
framework = espidf
monitor_raw = true
Bingo! Works. Using platform = https://github.com/platformio/platform-espressif32.git builds without issues.
Any reason why default platform = espressif32 gives issues and if it is planned to be fixed sometime soon?
Good to hear from you Max.
Well there isn’t really a problem, by using a specific platform version that’s meant to go with a specific (maximum( ESP-IDF version and using platform_packages to use a higher ESP-IDF version you’ve created a disconnect between the builder code and what package version it was meant to. The next stable package
The next stable platform version after 6.3.2 should have ESP-IDF 5.1.0 normally and you can reference that.
I’d like to use esp-idf task notification functions xTaskNotifyGive(Take)Indexed which require espidf 5.1+. With the current version of Platformio core 6.1.18 goes by default framework-espidf 3.4047 which supports espidf 4.4.7. I tried Installing 5.4.1 from Registry but saw the same issues as described here. How to run the latest espidf api in Platformio?
Duplicate of Code that Compiles in Espressidf does not in Platformio.
This post evaded me. It seems to address all my issues. Thank you!
