Hi, I cannot fix this kind of issue. When trying to build the project Im getting 0 problems but build process is never finished due to KeyError. Any idea how to fix it?
Here is terminal:
> Executing task in folder Test_Project_Framework: C:\Users\shalk\.platformio\penv\Scripts\pio.exe run <
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 (2.6.2) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
> esp@1.0.0 build
> webpack --mode=production
Browserslist: caniuse-lite is outdated. Please run:
npx browserslist@latest --update-db
Hash: 110bdeef2c8bae2456ea
Version: webpack 4.42.1
Time: 10103ms
Built at: 16. 12. 2020 14:25:23
Asset Size Chunks Chunk Names
./index.html 452 KiB [emitted] [big]
./index.html.gz 118 KiB [emitted]
bundle.js 448 KiB 0 [emitted] [big] main
bundle.js.gz 117 KiB [emitted]
main.css 3.52 KiB 0, 0 [emitted] main, main
main.css.gz 1.01 KiB [emitted]
Entrypoint main [big] = main.css main.css bundle.js
[1] ./node_modules/preact/compat/dist/compat.module.js + 2 modules 19.2 KiB {0} [built]
| 3 modules
[3] ./gui/js/configuration.json 927 bytes {0} [built]
[8] ./gui/js/dashboard.json 2.1 KiB {0} [built]
[11] (webpack)/buildin/global.js 472 bytes {0} [built]
[28] ./node_modules/@emotion/is-prop-valid/dist/is-prop-valid.browser.esm.js + 1 modules 4.41 KiB {0} [built]
| 2 modules
[70] ./gui/js/index.js + 343 modules 897 KiB {0} [built]
| ./gui/js/index.js 6.51 KiB [built]
| ./gui/js/comp/UiComponents.js 10 KiB [built]
| ./gui/js/comp/WifiPage.js 7.92 KiB [built]
| ./gui/js/functions/configHelpers.js 4.57 KiB [built]
| ./gui/js/comp/ConfigPage.js 1.96 KiB [built]
| ./gui/js/comp/DashboardPage.js 4.14 KiB [built]
| ./gui/js/comp/FilePage.js 393 bytes [built]
| ./gui/js/comp/FirmwarePage.js 7.62 KiB [built]
| ./gui/js/comp/DashboardItems.js 7.3 KiB [built]
| ./gui/js/comp/FileListing.js 8.48 KiB [built]
| ./gui/js/comp/ControlItem.js 5.52 KiB [built]
| ./gui/js/comp/DisplayItem.js 2.08 KiB [built]
| + 332 hidden modules
+ 403 hidden modules
WARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB).
This can impact web performance.
Assets:
bundle.js (448 KiB)
./index.html (452 KiB)
WARNING in entrypoint size limit: The following entrypoint(s) combined asset size exceeds the recommended limit (244 KiB). This can impact web performance.
Entrypoints:
main (452 KiB)
main.css
bundle.js
WARNING in webpack performance recommendations:
You can limit the size of your bundles by using import() or require.ensure to lazy load some parts of your application.
For more info visit https://webpack.js.org/guides/code-splitting/
Child html-webpack-plugin for "index.html":
1 asset
Entrypoint undefined = ./index.html
[0] ./node_modules/html-webpack-plugin/lib/loader.js!./gui/index.html 277 bytes {0} [built]
Child mini-css-extract-plugin ../ESP8266 IoT Framework\node_modules\css-loader\dist\cjs.js!../ESP8266 IoT Framework\node_modules\react-vis\dist\style.css:
Entrypoint mini-css-extract-plugin = *
2 modules
KeyError: 'value':
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 170:
File "C:\Users\shalk\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
File "C:\Users\shalk\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
File "C:\Users\shalk\.platformio\platforms\espressif8266\builder\main.py", line 238:
File "C:\Users\shalk\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1062:
project.install_dependencies()
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 880:
if _is_builtin(spec):
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 872:
for lb in self.env.GetLibBuilders():
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 993:
lb = LibBuilderFactory.new(env, lib_dir)
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 61:
obj = getattr(sys.modules[__name__], clsname)(env, path, verbose=verbose)
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 137:
self.process_extra_options()
File "C:\Users\shalk\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 282:
exports={"env": self.env, "pio_lib_builder": self},
File "C:\Users\shalk\Documents\PlatformIO\Projects\Test_Project_Framework\.pio\libdeps\esp12e\ESP8266 IoT Framework\scripts\preBuild.py", line 45:
preBuildConfigFun()
File "C:\Users\shalk\Documents\PlatformIO\Projects\Test_Project_Framework\.pio\libdeps\esp12e\ESP8266 IoT Framework\scripts\preBuildConfig.py", line 43:
cpp.write("\t" + str(item['value']).lower())
==================================================================== [FAILED] Took 20.84 seconds ====================================================================The terminal process "C:\Users\shalk\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
