Suddenly I cannot build my LittleFS filesystem. It worked this morning but now I get Error 3221225781. Building and uploading program works ok.
PS E:\C\Arduino\Elgrej_VSC> C:\Users\Peak\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'buildfs', '--environment', 'myEnv' --verbose
Processing myEnv (board: d1_mini; platform: espressif8266; framework: arduino; monitor_speed: 115200; board_build.filesystem: littlefs; board_build.flash_mode: dout; monitor_rts: 0; monitor_dtr: 1)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (4.0.1) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- tool-mkspiffs @ 1.200.0 (2.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
Found 35 compatible libraries
|-- ESP8266WebServer @ 1.0 (License: Unknown, Path: C:\Users\Peak\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WebServer)
| |-- ESP8266WiFi @ 1.0 (License: Unknown, Path: C:\Users\Peak\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi)
|-- LittleFS @ 0.1.0 (License: Unknown, Path: C:\Users\Peak\.platformio\packages\framework-arduinoespressif8266\libraries\LittleFS)
"mklittlefs" -c data -p 256 -b 8192 -s 1024000 .pio\build\myEnv\littlefs.bin
*** [.pio\build\myEnv\littlefs.bin] Error 3221225781
============================================== [FAILED] Took 1.97 seconds ==============================================
Any idea?
