I can not upload any code to any arduino. If I use arduino ide the code is uploaded without problem.
Even using an empty code I can’t upload it.
output on upload:
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
----------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Compiling .pio\build\nanoatmega328\src\main.cpp.o
Archiving .pio\build\nanoatmega328\libFrameworkArduinoVariant.a
Compiling .pio\build\nanoatmega328\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\Print.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\USBCore.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\WString.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\abi.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\hooks.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\main.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\new.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_pulse.S.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\nanoatmega328\libFrameworkArduino.a
Linking .pio\build\nanoatmega328\firmware.elf
Checking size .pio\build\nanoatmega328\firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 1.4% (used 444 bytes from 30720 bytes)
Building .pio\build\nanoatmega328\firmware.hex
AVAILABLE: arduino
Looking for upload port...
Use manually specified: COM8
Uploading .pio\build\nanoatmega328\firmware.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
avrdude done. Thank you.
*** [upload] Error 1
Any idea?
juanperez:
Write board = nanoatmega328new in the platformio.ini instead?
Yes, board is ok. not working with nanoatmega328new or nanoatmega328
Regards and sorry for delay
Please show a working verbose upload in the Arduino IDE (File → Preferences → Tick on “Verbose” for Upload) and the output for a non-working project tasks → Advanced → Verbose Upload.
Arduino IDE:
avrdude: Version 6.3-20190619
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Juan\AppData\Local\Temp\arduino_build_126460/sketch_feb24a.ino.hex"
avrdude: writing flash (2084 bytes):
Writing | ################################################## | 100% 0.29s
avrdude: 2084 bytes of flash written
avrdude: verifying flash memory against C:\Users\Juan\AppData\Local\Temp\arduino_build_126460/sketch_feb24a.ino.hex:
avrdude: load data flash data from input file C:\Users\Juan\AppData\Local\Temp\arduino_build_126460/sketch_feb24a.ino.hex:
avrdude: input file C:\Users\Juan\AppData\Local\Temp\arduino_build_126460/sketch_feb24a.ino.hex contains 2084 bytes
Reading | ################################################## | 100% 0.25s
avrdude: verifying ...
avrdude: 2084 bytes of flash verified
Platformio:
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino; upload_port: COM8; monitor_port: COM8; monitor_speed: 9600)
----------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
MethodWrapper(["checkprogsize"], [".pio\build\nanoatmega328\firmware.elf"])
.pio\build\nanoatmega328\firmware.elf :
section size addr
.data 0 8388864
.text 444 0
.bss 9 8388864
.comment 17 0
.note.gnu.avr.deviceinfo 64 0
.debug_aranges 64 0
.debug_info 1898 0
.debug_abbrev 1482 0
.debug_line 258 0
.debug_str 520 0
Total 4756
<lambda>(["upload"], [".pio\build\nanoatmega328\firmware.hex"])
AVAILABLE: arduino
BeforeUpload(["upload"], [".pio\build\nanoatmega328\firmware.hex"])
avrdude -v -p atmega328p -C C:\Users\Juan\.platformio\packages\tool-avrdude\avrdude.conf -c arduino -b 57600 -D -P COM8 -U flash:w:.pio\build\nanoatmega328\firmware.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
System wide configuration file is "C:\Users\Juan\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : COM8
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x37
Regards
Wrong baud in PlatformIO, right baud (115200) in Arduino IDE. Are you 100% sure you wrote nanoatmega328new in the platformio.ini? Did you use the project environment switcher to select the right project?
in the .ini file remove all other board configurations besides the one you are using
