Hello, I can’t check my code in inspect tab. How can I fix this error(I skipped some text in error, because there were memory dump)
Undefines:
Includes: -I/Users/michal/IT/Robots_of_education/Code/Robots/include/ -I/Users/michal/IT/Robots_of_education/Code/Robots/src/ -I/Users/michal/IT/Robots_of_education/Code/Robots/.pio/libdeps/unoR3/Dictionary/src/ -I/Users/michal/IT/Robots_of_education/Code/Robots/.pio/libdeps/unoR3/ArduinoJson/src/ -I/Users/michal/.platformio/packages/framework-arduino-avr/cores/arduino/ -I/Users/michal/.platformio/packages/framework-arduino-avr/variants/standard/ -I/Users/michal/.platformio/packages/framework-arduino-avr/libraries/EEPROM/src/ -I/Users/michal/.platformio/packages/framework-arduino-avr/libraries/HID/src/ -I/Users/michal/.platformio/packages/framework-arduino-avr/libraries/SPI/src/ -I/Users/michal/.platformio/packages/framework-arduino-avr/libraries/SoftwareSerial/src/ -I/Users/michal/.platformio/packages/framework-arduino-avr/libraries/Wire/src/ -I/Users/michal/.platformio/packages/toolchain-atmelavr/lib/gcc/avr/7.3.0/include/ -I/Users/michal/.platformio/packages/toolchain-atmelavr/lib/gcc/avr/7.3.0/include-fixed/ -I/Users/michal/.platformio/packages/toolchain-atmelavr/avr/include/ -I/Users/michal/.platformio/packages/tool-unity/
Platform:Unspecified
Error: Found a breaking defect ‘syntax error’ in /Users/michal/.platformio/packages/toolchain-atmelavr/avr/include/stdlib.h:162
Please note: check results might not be valid!
Try adding --skip-packages
“severity=error<&PIO&>message=syntax error<&PIO&>file=/Users/michal/.platformio/packages/toolchain-atmelavr/avr/include/stdlib.h<&PIO&>line=162<&PIO&>column=65<&PIO&>callstack=[/Users/michal/.platformio/packages/toolchain-atmelavr/avr/include/stdlib.h:162]<&PIO&>cwe=0<&PIO&>id=syntaxError”
src/Message/Device.cpp:18: [low:style] The function ‘getPinsPtr’ is never used. [unusedFunction]
src/Message/Device.cpp:13: [low:style] The function ‘setPins’ is never used. [unusedFunction]
src/Message/Task.cpp:77: [low:style] Condition ‘extraValues=nullptr’ is always false [knownConditionTrueFalse]
src/Message/Task.cpp:42: [low:style] The function ‘getExtraValue’ is never used. [unusedFunction]
src/Message/Task.cpp:96: [low:style] The function ‘getExtraValuesSize’ is never used. [unusedFunction]
src/Message/Task.cpp:22: [low:style] The function ‘getTask’ is never used. [unusedFunction]
src/Message/Task.cpp:75: [low:style] The function ‘setExtraValue’ is never used. [unusedFunction]
src/Message/Task.cpp:115: [low:style] The function ‘setExtraValuesSize’ is never used. [unusedFunction]
src/Message/VMsgContainer.cpp:12: [low:style] The function ‘getDevType’ is never used. [unusedFunction]
src/Message/VMsgContainer.cpp:37: [low:style] The function ‘getID’ is never used. [unusedFunction]
src/Message/VMsgContainer.cpp:7: [low:style] The function ‘setDevType’ is never used. [unusedFunction]
src/Message/VMsgContainer.cpp:32: [low:style] The function ‘setID’ is never used. [unusedFunction]
Error: cppcheck failed to perform check! Please examine tool output in verbose mode.
Component HIGH MEDIUM LOW
src/Message 0 0 12
Total 0 0 12
========================= [FAILED] Took 12.15 seconds =========================
Environment Tool Status Duration
nanoNew cppcheck IGNORED
test_nanoNew cppcheck IGNORED
debug_nanoNew cppcheck IGNORED
unoR3 cppcheck FAILED 00:00:12.149
test_unoR3 cppcheck IGNORED
debug_unoR3 cppcheck IGNORED
native cppcheck IGNORED
==================== 1 failed, 0 succeeded in 00:00:12.149 ====================
