Can not compile: arm-none-eabi-g++: command not found
Thank you for your fast answer!
I did it and it started compiling, then showed some No such file or
directory and Failed.
The packages though were reported as successfully installed, so I compiled it again and it worked!
Thanks for your help @maxgerhardt , you’re great!
Guido
