I am working on a can project using the EPS32 device and a can transceiver, I’ve found many libraries online but they seem to not work for me for some reason. One of the, in particular which seemed to be the most complete one: GitHub - sandeepmistry/arduino-CAN: An Arduino library for sending and receiving data using CAN bus..
Whenever I try to compile it, I have these parameters undefined, any ideas of what I can do about it?
lib/CAN/CAN.c:171:53: error: ‘DPORT_CAN_CLK_EN’ undeclared (first use in this function); did you mean ‘DPORT_REG_CLR_BIT’?
DPORT_SET_PERI_REG_MASK(DPORT_PERIP_CLK_EN_REG, DPORT_CAN_CLK_EN);
C:/Users/radu.rotaru/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:75:88: note: in definition of macro ‘_DPORT_WRITE_PERI_REG’
#define _DPORT_WRITE_PERI_REG(addr, val) (*((volatile uint32_t )(addr))) = (uint32_t)(val)
C:/Users/radu.rotaru/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:88:46: note: in expansion of macro ‘DPORT_WRITE_PERI_REG’
#define DPORT_SET_PERI_REG_MASK(reg, mask) DPORT_WRITE_PERI_REG((reg), (DPORT_READ_PERI_REG(reg)|(mask)))
lib/CAN/CAN.c:171:5: note: in expansion of macro ‘DPORT_SET_PERI_REG_MASK’
lib/CAN/CAN.c:172:31: error: ‘DPORT_PERIP_RST_EN_REG’ undeclared (first use in this function); did you mean ‘SYSTEM_PERIP_RST_EN0_REG’?
DPORT_CLEAR_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
C:/Users/radu.rotaru/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:75:67: note: in definition of macro ‘_DPORT_WRITE_PERI_REG’
#define _DPORT_WRITE_PERI_REG(addr, val) (((volatile uint32_t )(addr))) = (uint32_t)(val)
C:/Users/radu.rotaru/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:85:46: note: in expansion of macro ‘DPORT_WRITE_PERI_REG’
#define DPORT_CLEAR_PERI_REG_MASK(reg, mask) DPORT_WRITE_PERI_REG((reg), (DPORT_READ_PERI_REG(reg)&(~(mask))))
lib/CAN/CAN.c:172:5: note: in expansion of macro ‘DPORT_CLEAR_PERI_REG_MASK’
lib/CAN/CAN.c:172:55: error: ‘DPORT_CAN_RST’ undeclared (first use in this function); did you mean ‘DPORT_DATE_REG’?
#define _DPORT_WRITE_PERI_REG(addr, val) (((volatile uint32_t *)(addr))) = (uint32_t)(val)
lib/CAN/CAN.c:176:39: error: ‘CAN_TX_IDX’ undeclared (first use in this function); did you mean ‘TWAI_TX_IDX’?
gpio_matrix_out(CAN_cfg.tx_pin_id,CAN_TX_IDX,0,0);
TWAI_TX_IDX
lib/CAN/CAN.c:181:35: error: ‘CAN_RX_IDX’ undeclared (first use in this function); did you mean ‘TWAI_RX_IDX’?
gpio_matrix_in(CAN_cfg.rx_pin_id,CAN_RX_IDX,0);
TWAI_RX_IDX
lib/CAN/CAN.c:242:20: error: ‘ETS_CAN_INTR_SOURCE’ undeclared (first use in this function)
