I have not characterized this to a fully repeatable procedure yet but here is what has been happening. I clean, compile, start debugging hit a breakpoint, step thru some code, step into and over some functions. I am using Teraterm to access my ESP32 over the USB serial port.
I fix a bug. Stop the debugger. Rebuild. When I try to restart debugging my ESP32 panics and enters a reboot loop. I can get it out of the boot loop by randomly trying some of these:
Power cycle the debugger
Power cycle the ESP32 board
Restart my PC
Upload my program over serial instead of letting the debugger do it
Start up the Arduino IDE and load a small sketch.
I have always been able to get back to debugging on PlatformIO but that does not last too long. I am attaching my platform.ini and several other files.
Sorry about the big cut/paste, is there a preferred way to do this?
Thanks,
Tony
PlatformIO
debug_build_flags = -Og -ggdb -g3 -D ESP32_Board
board = nodemcu-32s
build_type = debug
debug_tool = esp-prog
upload_port = COM5
Debug Console
Reading symbols from d:\AllDev\DevSW\Trains-Aurduino\platformIO\DCCLogicAnalyzerWorkspace\Projects\DCC_LogicAnalyzer\.pio\build\esp32dev\firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20210721 (2021-07-21-13:35)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x4000854A, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu0: Target halted, PC=0x400928DA, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 64 KB
Info : Flash mapping 1: 0x30018 -> 0x400d0018, 132 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 136 KB
Info : Using flash bank 'esp32.cpu0.drom' size 68 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
0x4000854a in ?? ()
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Info : PROF: Data transferred in 156.246 ms @ 128.003 KB/s
** Programming Finished **
** Verify Started **
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 31.262 ms @ 127.951 KB/s
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 62.499 ms @ 128.002 KB/s
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 1625.46 ms @ 162.416 KB/s
** Verified OK **
** Verified OK **
Temporary breakpoint 1 at 0x400d2e84: file src\DCCAnalyzer-LA.cpp, line 1979.
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
Info : esp32.cpu0: Target halted, PC=0x40086F9F, debug_reason=00000000
Info : esp32.cpu0: Detected debug stubs @ 3ffc1c90
Info : esp32.cpu1: Target halted, PC=0x400D2E84, debug_reason=00000001
Warn : Not full dbg stub table 1 of 2
[New Thread 1073465364]
[New Thread 1073463952]
[New Thread 1073468060]
[New Thread 1073456088]
[New Thread 1073445228]
[New Thread 1073454676]
[New Thread 1073462540]
[Switching to Thread 1073447000]
1, setup () at src\DCCAnalyzer-LA.cpp:1979
1979 {
Info : esp32.cpu0: Target halted, PC=0x400855FC, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x400E8E24, debug_reason=00000001
Program received signal
SIGTRAP, Trace/breakpoint trap.
mcpwm_capture_signal_get_value (mcpwm_num=(unknown: 1073078272), cap_sig=(unknown: 1073422032)) at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/mcpwm.c:683
683 /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/driver/mcpwm.c: No such file or directory.
Terminal Console after build
> Executing task in folder DCC_LogicAnalyzer: C:\Users\tbvin\.platformio\penv\Scripts\platformio.exe debug <
Processing esp32dev (platform: espressif32; board: nodemcu-32s; framework: arduino)
--------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (3.5.0) > NodeMCU-32S
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 28 compatible libraries
|-- <EEPROM> 1.0.3
Building in debug mode
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 5.6% (used 18328 bytes from 327680 bytes)
Flash: [== ] 19.6% (used 257338 bytes from 1310720 bytes)
=================== [SUCCESS] Took 1.44 seconds ===================
|-- <EEPROM> 1.0.3
Flash: [== ] 19.7% (used 257726 bytes from 1310720 bytes)
=================== [SUCCESS] Took 1.47 seconds ===================
ESP32 Panic, the first lines are from a working project, then after
Starting the debugger panic lines
1111111111111 0 11111111 0 00000000 0 11111111 1
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
Idle Pkt
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
Guru Meditation Error: Core 1 panic'ed (Cache disabled but cached memory region accessed)
Core 1 register dump:
PC : 0x400e8cec PS : 0x00060034 A0 : 0x40083c6c A1 : 0x3ffbeb40
A2 : 0x10000000 A3 : 0x00000200 A4 : 0x00040000 A5 : 0x40088758
A6 : 0x00000000 A7 : 0xffffffff A8 : 0x8008125a A9 : 0x00000000
A10 : 0x00000000 A11 : 0x00000001 A12 : 0x8008aad1 A13 : 0x3ffb1c00
A14 : 0x00000000 A15 : 0x3ffb1c3c SAR : 0x00000015 EXCCAUSE: 0x00000007
EXCVADDR: 0x00000000 LBEG : 0x40001609 LEND : 0x4000160d LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x4008ac37 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x400e8cec
ELF file SHA256: 0000000000000000
Backtrace: 0x400e8cec:0x3ffbeb40 0x40083c69:0x3ffbeb60 0x4008ac34:0x3ffb1c60 0x4008b36d:0x3ffb1c80 0x4008462c:0x3ffb1ca0 0x400ecc51:0x3ffb1d10 0x400eb521:0x3ffb1d30 0x400eb953:0x3ffb1d50 0x400ea337:0x3ffb1dc0 0x400ea719:0x3ffb1e10 0x400ea847:0x3ffb1e90 0x400e99c1:0x3ffb1ef0 0x400e9e69:0x3ffb1f30 0x400d6375:0x3ffb1f50 0x400d2f64:0x3ffb1f80 0x400d7bb2:0x3ffb1fb0 0x40086595:0x3ffb1fd0
Rebooting...
entry 0x400806a8
A2 : 0x10000000 A3 : 0x3ffb1ed0 A4 : 0x3ff42000 A5 : 0x40088758
A10 : 0x00000000 A11 : 0x00000001 A12 : 0x8008aad1 A13 : 0x3ffb1c80
A14 : 0x00000000 A15 : 0x3ffb1cbc SAR : 0x00000017 EXCCAUSE: 0x00000007
EPC1 : 0x4008ac3d EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x400e8cec
