I have a pre-script that I use to pre-generate some files. I would like to use the C preprocessor to pre-process my input file (json) so that I can benefit from the #include and #ifdef directives before acutally processing the input json file.
I checked env, and I could not see anything usefull. I just need the cross compiler gcc path. env[“CC”] is equal to “cc” but I need the target gcc not the host one (to avoid having to install yet an other tool in my host).
thank you for the quick reply.
I checked again the link “duplicate” and I still fail to see how I can do it.
My point is that I need the xtensa or arm gcc, and env is returning me the host gcc.
I’ve searched all the links in the link you provided, and I see this:
Seems like there is no way to easily get the gcc of the toolchain without creating a search function myself?
If I can get ~/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc I will be happy!
Import("env")
def search_compiler(env):
from pathlib import Path, PurePath
# Use any item in $PATH corresponding to a platformio toolchain bin folder
path_separator = ':'
gcc_exe = '*g++'
if env['PLATFORM'] == 'win32':
path_separator = ';'
gcc_exe += ".exe"
# Search for the compiler in PATH
for ppath in map(Path, env['ENV']['PATH'].split(path_separator)):
if ppath.match(env['PROJECT_PACKAGES_DIR'] + "/**/bin"):
for gpath in ppath.glob(gcc_exe):
gccpath = str(gpath.resolve())
return gccpath
gccpath = env.get('CXX')
return gccpath
compiler = search_compiler(env)
print("Got compiler: " + str(compiler))
max@XXXX:~/temp/pio_find_compiler$ pio run -v
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino; extra_scripts: test.py)
PLATFORM: Espressif 32 (6.0.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20006.221224 (2.0.6)
- tool-esptoolpy @ 1.40400.0 (4.4.0)
Found 33 compatible libraries
Got compiler: /home/max/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/xtensa-esp32-elf-g++
"/home/max/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/xtensa-esp32-elf-g++" --version
xtensa-esp32-elf-g++ (crosstool-NG esp-2021r2-patch5) 8.4.0
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
xtensa-esp32-elf-g++ --version
It really can’t get simpler and more elegant than that. SCons variable substitions in env.Execute() take care of it all.
Thanks!
I think I know what is the problem: in my case $CC is just cc, $CXX is g++ etc… and my script is a pre-script…
Seems like it is run before all the variables are set!
And I need to run before the compilation is started.
I’ve used in the past something like env.AddPreAction("buildprog", before_build) but it never worked (I suspect that the “buildprog” target does not exist anymore as “before_build” is never exectued)
ok, got it. My issue was that the AddPreAction(“buildprog”… is only called if there is something to build! This is neat, but since I generate header files, I cannot rely on that mechanism.
So I’m facing a dilemma… If I use pre:extra_script.py, I got executed before the LDF and anything in platformio, but then the env is still not complete.
Or if I remove “pre:” and use a condition like in the link (is_pio_build()), the env is complete, but then I run after the LDF
This is maybe not a problem, since I explicitely set the deps here.
Anyway, thanks for your help, I have all the info I need to continue now! Thanks a lot!
Just for information, it seems like I need to go back using a pre-extra script… When doing a clean build (ie, no generated source files yet), I can see the file being generated after the dependency graph being displayed and before the first compilation starts… however it does not pick up my generated C files for compilation (this is the case for ldf default value and ldf off)
If I run the compilation a second time, then it works (because the files are already generated)
Too bad, I didn’t expect this problem to be this difficult
