Hi all,
I am attempting to use the C++ STL in a STM32Cube project to implement some queues and vectors, but when I try to include any STL headers (i.e. <vector.h>) I get an include error.
Any help would be appreciated!
Shane
Hi all,
Shane
Minimal code example and platformio.ini
please. Are you trying to include it from a C file? STM32Cube is inherently a C framework.
Also, an embedded system might not support the entirty of the C++ STL (and you also shouldn’t use all of it, as some data structures alloc stuff on the heap, and heap fragmentation is a killer on embedded systems)
in order to include vector you simply write
#include <vector>
int main()
std::vector<int> myVec;
if that’s not the problem, please post the error message(s).
Oh and just an addendum, to include the C++ standard header for vectors you do #include <vector>
, not #include <vector.h>
. That may already explain your error.
I was including <vector.h>
instead of <vector>
- my bad, total brain fart. Thanks everyone!
