I write a program for Teensy 2.0 in ANSI C, but I can only compile it if the file extension is *.cpp
or .ino
. Having in mind that pure C is valid C++ syntax why I get compilation errors for almost every single line of code?
ini file:
[env:teensy20]
platform = teensy
board = teensy20
build_flags = -D USB_MIDI
Am I missing something in the configuration of the project? By the way I have included the arduino library header #include <Arduino.h>
on top of the program.
