Hi there –
I’ve tried altering c_cpp_properties.json to provide my own path for avr-gcc/include etc.
It works great till until I clode VSCode and reopen it. Then c_cpp_properties.json gets wiped clean and my includePath are gone…
Disabling Platformio Extension fixes the issue but I’m losing all the other benefits…
Cheers,
– Ladislas
That is normal behavior. Use Redirecting... to manage C/C++ flags
Well no I’m talking about that. I know how to set my own flags and I’m already using it with great success when compiling – everything works fine here.
I’m talking about Intellisense with VSCode and the includePath it uses to provide autocompletion and magic while coding.
It is located here: $ProjectName/.vscode/c_cpp_properties.json – everytime I open VSCode, the modification I have made are removed.
Which modifications did you do for this file?
I reopen this thread, because after googling there is no answer to this problem.
I use platformio (core 6.1.6, home 3.4.3) with platfom ST STM32 15.4.1.
At each vscode openning, the $ProjectName/.vscode/c_cpp_properties.json is reseted by whom? i do not know!
The c_cpp_properties.json contains a STM32 platform path with escape char. (Escaped bracket \( and \) for my case)
Example:
“/home/user/.platformio/packages/framework-arduinoststm32/variants/STM32F4xx/F427Z(G-I)T_F429ZET_F429Z(G-I)(T-Y)_F437Z(G-I)T_F439Z(G-I)(T-Y)”.
The IntelliSense say that this line is faulty due to the presence of the escape chars, and so in my code all #include <Arduino.h> are not found by intelliSense.
So at each opening, i unescape manually the c_cpp_properties.json. All comes back to normal then.
But if i close and re-open again vscode, this file is overwrite. And so i have to unescape the file again.
How to correct this behavior ? Is this the correct forum ?
Regards
Thank a lot. It is working now.
The solution was to force an update of the ST STM32 even if updated version has the same number.
To update, i have done:
Open platformio home (The little house at the bottom of VsCode)
Go to Platforms on the left vertical menu
Select the “ST STM32” platform.
Select “Updates” (Top bar)
Select “Update”
