I’m trying to use the ButtonEvent library found here: https://github.com/fasteddy516/ButtonEvents
I was unable to search for it in the Libraries and manually dragged and dropped it into my lib folder.
When I try to build my project in PlatformIO, I get the following error:
error: request for member ‘attach’ in ‘ledEyesButton’, which is of non-class type ‘ButtonEvent’
However, if I jump over to Arduino IDE, the project builds.
What am I doing wrong?
Please provide more information:
- the
platformio.ini
file
- the main source file (probably
main.cpp
- the full build log
Did you get any other errors when compiling?
You copied ButtonEvents.h
and ButtonEvents.cpp
into your lib
folder? You should have created a ButtonEvents
folder in lib
first, and dropped the two files there.
ButtonEvents.h
has this line:
#include <Bounce2.h> // use Thomas Fredericks' button debounce library
So, you will need that library’s source and header files in lib/Bounce2
as well. It’s a dependency. That library is available at PlatformIO Registry so, add this to platformio.ini
lib_deps=
thomasfredericks/Bounce2
https://github.com/fasteddy516/ButtonEvents.git
And remove the code files you dropped into lib
, it should work.
I suspect your code failed to include the Bounce2 header and so, failed to compile the ButtonEvents class, hence the error message.
Cheers,
Norm.
The easiest way to deal with libraries is to simply declare them in platformio.ini
. So a simple project could look like so. Note that the lib
folder is empty.
platformio.ini
[env:uno]
board = uno
main.cpp
#include <ButtonEvents.h>
const byte buttonPin = 7;
ButtonEvents myButton;
pinMode(buttonPin, INPUT_PULLUP);
myButton.attach(buttonPin);
Serial.begin(9600);
Serial.println("ButtonEvents 'basic' example started");
myButton.update();
if (myButton.tapped() == true) {
Serial.println("TAP event detected");
if (myButton.doubleTapped() == true) {
Serial.println("DOUBLE-TAP event detected");
if (myButton.held() == true) {
Serial.println("HOLD event detected");
PlatformIO has a Libraries page that can help you locate libraries. It finds Bounce2 and can even add it to your platformio.ini
file.
ButtonEvents is not registered. But you can simply add the Git URL instead.
