This might not be the correct subforum (feel free to move). I’m trying to burn an efuse using espefuse.py, however it looks like it’s not installing the pip dependencies. I’m running:
$ pio pkg exec -- espefuse.py
Using tool-esptoolpy@1.40501.0 package
File "/home/kevin/.platformio/packages/tool-esptoolpy/espefuse.py", line 31, in <module>
import espefuse
File "/home/kevin/.platformio/packages/tool-esptoolpy/espefuse/__init__.py", line 11, in <module>
import espefuse.efuse.esp32 as esp32_efuse
File "/home/kevin/.platformio/packages/tool-esptoolpy/espefuse/efuse/esp32/__init__.py", line 1, in <module>
from . import operations
File "/home/kevin/.platformio/packages/tool-esptoolpy/espefuse/efuse/esp32/operations.py", line 11, in <module>
import espsecure
File "/home/kevin/.platformio/packages/tool-esptoolpy/espsecure/__init__.py", line 15, in <module>
from cryptography import exceptions
ModuleNotFoundError: No module named 'cryptography'
I’ve tried pip installing the cryptography module, but it leads to other dependency issues (and it may not be installing the correct versions, etc), so I’m hesitant on going this route.
How do I correctly handle these missing dependencies? Is this a bug and should I open an issue on Github?
