Burn Bootloader for a custom Atmega328P board
I have some custom atmega328P board that have no bootloader on. I am using arduino IDE to burn a new bootloader with a UNO board.
Now, I want to use the burn bootloader of platformIO but I am not able to make it work even if I got a success message after burn bootloader.
What i don’t understand is that i have a success message whereas I am still unable to upload a simple program to my board. When I do the same operation with arduino ide. I don’t have those issue.
I don’t really understand if it is possible to burn bootloader whithout using a script suggest in this warning message :
Warning: The custom upload protocol is used! The upload and fuse flags may conflict!
I am just using the programmer “arduino as isp” used in arduino IDE too : Atmel AVR — PlatformIO latest documentation
With some extra argument such as :
board_hardware.oscillator = external ; added
board_build.f_cpu = 4000000L ;added 4 MHz
I got the following platformio.ini configuration
platformio.ini
[common_env_data]
src_filter = ${env.src_filter}  +<bootloader.cpp>
[env:uno]
board = uno
[env:program_via_ArduinoISP]
platform = ${common_env_data.platform}
framework =${common_env_data.framework}
board = atmega328p
upload_protocol = custom
upload_port = COM10
upload_speed = 19200
upload_flags =
    -C
    ; use "tool-avrdude-megaavr" for the atmelmegaavr platform
    -p
    $BOARD_MCU
    -P
    $UPLOAD_PORT
    -b
    $UPLOAD_SPEED
    -c
    stk500v1
src_filter =${common_env_data.src_filter}
lib_extra_dirs =
    /lib
If I try to understand what is doing burn bootloader:
  • it first recognize the target device with its signature
  • then it check the fuses
  • finally it upload the bootloader
result after burn bootloader platformio
Executing task in folder bootloader: C:\Users\name_user\.platformio\penv\Scripts\platformio.exe run --target bootloader --environment p
Processing program_via_ArduinoISP (platform: atmelavr; framework: arduino; board: atmega328p)
------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/atmega328p.html
PLATFORM: Atmel AVR (3.3.0) > ATmega328P/PA
HARDWARE: ATMEGA328P 4MHz, 2KB RAM, 32KB Flash
 - framework-arduino-avr-minicore 2.1.1
Found 19 compatible libraries
|-- <SPI> (C:\Users\name_user\Documents\Code\platform\project\bootloader\lib\SPI)
|-- <Wire> 1.0 (C:\Users\name_user\.platformio\packages\framework-arduino-avr-minicore\libraries\Wire)
TARGET CONFIGURATION:
Target = atmega328p
Clock speed = 4000000L
Oscillator = external
BOD level = 2.7v
Save EEPROM = yes
UART port = uart0
Clock output = no
Warning: The `custom` upload protocol is used! The upload and fuse flags may conflict!
More information: https://docs.platformio.org/en/latest/platforms/atmelavr.html#overriding-default-fuses-command
Selected fuses: [lfuse = 0xf7, hfuse = 0xd6, efuse = 0xfd]
More information: https://docs.platformio.org/en/latest/platforms/atmelavr.html#overriding-default-bootloader-command
avrdude -p atmega328p -C "C:\Users\name_user\.platformio\packages\tool-avrdude\avrdude.conf" -e -C C:\Users\name_user\.platformio\d6:m -Ulfuse:w:0xf7:m -Uefuse:w:0xfd:m
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xd6"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd6:
avrdude: load data hfuse data from input file 0xd6:
avrdude: input file 0xd6 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xf7"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xf7:
avrdude: load data lfuse data from input file 0xf7:
avrdude: input file 0xf7 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xfd"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfd:
avrdude: load data efuse data from input file 0xfd:
avrdude: input file 0xfd contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: safemode: Fuses OK (E:FD, H:D6, L:F7)
avrdude done.  Thank you.
avrdude -p atmega328p -C "C:\Users\name_user\.platformio\packages\tool-avrdude\avrdude.conf" -C C:\Users\name_user\.platformio\pacigeon\.platformio\packages\framework-arduino-avr-minicore\bootloaders\optiboot_flash\bootloaders\atmega328p\4000000L\optiboot_flash_atmega328p_U
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: reading input file "C:\Users\name_user\.platformio\packages\framework-arduino-avr-minicore\bootloaders\optiboot_flash\bootloader
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% -0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against C:\Users\name_user\.platformio\packages\framework-arduino-avr-minicore\bootloaders\optiboot_flash
avrdude: load data flash data from input file C:\Users\name_user\.platformio\packages\framework-arduino-avr-minicore\bootloaders\optiboot
avrdude: input file C:\Users\name_user\.platformio\packages\framework-arduino-avr-minicore\bootloaders\optiboot_flash\bootloaders\atmega3
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0F"
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
=============================================================================================================== [SUCCESS] Took 4.01 seconds ====
Environment             Status    Duration
program_via_ArduinoISP  SUCCESS   00:00:04.014
=============================================================================================================== 1 succeeded in 00:00:04.014 ====
arduino IDE burn bootloader
C:\Users\name_user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/avrdude.conf -v -patmega328p -cstk500v1 -PCOM10 -b19200 -Uflash:w:C:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/bootloaders/optiboot_flash/bootloaders/atmega328p/4000000L/optiboot_flash_atmega328p_UART0_9600_4000000L_B5.hex:i -Ulock:w:0x0f:m
avrdude: Version 6.3-20201216
         System wide configuration file is "C:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/avrdude.conf"
         Using Port                    : COM10
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: reading input file "C:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/bootloaders/optiboot_flash/bootloaders/atmega328p/4000000L/optiboot_flash_atmega328p_UART0_9600_4000000L_B5.hex"
Writing | ################################################## | 100% 0.00s
avrdude: verifying flash memory against C:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/bootloaders/optiboot_flash/bootloaders/atmega328p/4000000L/optiboot_flash_atmega328p_UART0_9600_4000000L_B5.hex:
avrdude: load data flash data from input file C:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/bootloaders/optiboot_flash/bootloaders/atmega328p/4000000L/optiboot_flash_atmega328p_UART0_9600_4000000L_B5.hex:
avrdude: input file C:\Users\name_user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2/bootloaders/optiboot_flash/bootloaders/atmega328p/4000000L/optiboot_flash_atmega328p_UART0_9600_4000000L_B5.hex contains 32768 bytes
Reading | ################################################## | 100% -0.00s
avrdude: reading input file "0x0f"
Writing | ################################################## | 100% 0.03s
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
Have a nice day :slight_smile:
Is there someone who was successful with platformio burn bootloader ?
Or any idea how I could debug my config to burn a bootloader correctly with platformio ?
I am not really famillar with bootloader. I am starting to understand a bit how avrdude works.
It appears that you might not be burning a bootloader? In the output, I see this avrdude command – which I’ve split over a few lines for clarity:
-C "C:\Users\USER_NAME\.platformio\packages\tool-avrdude\avrdude.conf"
-C C:\Users\USER_NAME\.platformio\pacigeon\.platformio\packages\framework-arduino-avr-minicore\bootloaders\optiboot_flash\bootloaders\atmega328p\4000000L\optiboot_flash_atmega328p_U
The weird thing here is, as far as I can see, you are specifying the avrdude config file twice using the -C option. The first is the (correct) config file but the second is this:
Again, I’ve split the line to make it a bit more readable. I see what looks like bits of the command line and bits of the bootloader file all mixed in there - is that path correct?
I would expect to see a command something like:
-c <upload protocol of some kind>
-Uflash:w:<your bootloader hex file>:i
-Ulock:w:<atmega328p lock byte address>:m
Just for “fun” I connected up an Uno and burned the default bootloader. Obviously, using an ICSP to actually burn it:
pio run -t bootloader
Using the command line there by the way. My platformio.ini looks like this:
[env:uno]
board = uno
board_bootloader.file = /home/norman/.platformio/packages/framework-arduino-avr/bootloaders/optiboot/optiboot_atmega328.hex
board_bootloader.lfuse = 0xFF
board_bootloader.hfuse = 0xDE
board_bootloader.efuse = 0xFD
board_bootloader.lock_bits = 0x0F
board_bootloader.unlock_bits = 0x3F
upload_flags =
    -C
    -p
    $BOARD_MCU
    -c
    usbtiny
the full output was this:
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.3.0) > Arduino Uno
 - framework-arduino-avr 5.1.0
Found 5 compatible libraries
Selected fuses: [lfuse = 0xFF, hfuse = 0xDE, efuse = 0xFD]
Setting fuses
avrdude: reading input file "0xDE"
avrdude: verifying hfuse memory against 0xDE:
avrdude: load data hfuse data from input file 0xDE:
avrdude: input file 0xDE contains 1 bytes
avrdude: reading input file "0xFF"
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading input file "0xFD"
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: safemode: Fuses OK (E:FD, H:DE, L:FF)
Uploading bootloader
avrdude: reading input file "/home/norman/.platformio/packages/framework-arduino-avr/bootloaders/optiboot/optiboot_atmega328.hex"
avrdude: verifying flash memory against /home/norman/.platformio/packages/framework-arduino-avr/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: load data flash data from input file /home/norman/.platformio/packages/framework-arduino-avr/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: input file /home/norman/.platformio/packages/framework-arduino-avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
========================= [SUCCESS] Took 1.60 seconds
I think you also have fuse problems. At the end of the burn, I see that your fuses are set to:
  • Low: F7 => 1111 0111 = CKSEL3
  • High: D6 => 1101 0110 = SPIEN, EESAVE, BOOTRST
  • Extended: FD => 1111 1101 = BODLEVEL1
a 1 bit means unprogrammed while a zero bit is programmed.
In your low fuse setting, CKSEL3 means that the four CKSEL bits are 1000 and means that you are using an external crystal attached to pins 9 and 10 of the ATmeag328P.
Unfortunately, CKSEL bits 3, 2 and 1 are 100 here, and those define an oscillator speed of 0.4 to 0.9 MHz. You need to have those bits set to 110 to get a frequency between 3 and 8 MHz. (You wanted 4 MHz I believe?)
So, your low fuse needs to be CKSEL3 and CKSEL2 at the very least, this is a value of F3 for the low fuse. Plus you might need to play with SUT1 and SUT0 to get a decent startup delay to allow the power and oscillator to stabilise. The data sheet has the gory details.
Your extended fuse value is set to BODLEVEL1 on it’s own which gives a system reset by the Brown Out Detector at 2.7V. If you are intending to run with a 4MHz crystal, then your operating voltages are from 1.8V to 5.5V so this might be applicable. However, with a VCC of 2.7V or below, the BOD will constantly reset the device!
HTH
Cheers,
Norm.
Thanks you a lot. I know where to look now.
I didn’t precise in my explanation but I am using an external clock at 4Mhz and my board is at 1.8V.
So I need to disable BOD and fix baudrate.
I found a really good example for avrdude with Platformio here in this doc in the arduino folder : C:\Users\username\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.2
Edit :
This is my new config which is working now !
[env:fuses_bootloader]
board = atmega328p
board_hardware.oscillator = external ; Oscillator type
board_hardware.uart = uart0          ; Set UART0 to use for serial upload
board_bootloader.speed = 9600      ; Set bootloader baud rate
board_hardware.bod = disabled            ; Set brown-out detection
board_hardware.eesave = yes          ; Preserve EEPROM when uploading using programmer
upload_port = COM10
upload_speed = 19200 ;
upload_flags =
  -C
  -p
  $BOARD_MCU
  -P
  $UPLOAD_PORT
  -b
  $UPLOAD_SPEED
  -c
  stk500v1
Thanks for the fuses calculator @NormanDunbar, I found another one but it was no longer hosted
This web site is a decent AVR fuse calculator, if you need one.
I use it all the time when checking or messing around with fuse settings.
Cheers,
Norm.
