I’d like to build a simple command-line based debugging/hacking/tweaking tool to inspect and modify variables while a sketch is running into many of my sketches. My goal with this is to be able to connect to running systems and tweak some settings in real-time or see what state they’re in. Similar to a very limited debugger.
The question I have is how best to implement that, specifically, how to create the meta-data that is needed to name and locate the variables.
For example, I may have a global variable rexmit_timeout that is the current retransmission timeout for some RF data packets and with this tool I could connect and change the timeout “live” to test something. Or I may have a variable that has the time of the last received ping response and where there is a problem I could connect and see what the value is.
I’m primarily targeting the esp32 with this, but it could also work for other microcontrollers. The command-line could be over the serial port or a network connection.
In terms of implementation, my first attempt uses a C++ class and a #define. Instead of writing something like
static uint32_t lastPing = 0
I write
static DBGVAR(uint32_t, lastPing, 0);
which is macro-expanded to
static uint32_t lastPing = 0; DBGVAR __lastPing("lastPing", &lastPing, 4);
where DBGVAR is a class whose constructor takes the name of the variable, its address and size, packages that up into a descriptor, and inserts that into a global linked-list.
This approach works, but requires that all variables that are to be accessible are specially coded using the macros and it sucks from a readability point of view.
What I’d really like is to extract the set of global variables in the main application files from the ELF symbol or debug info, then generate the meta-data, and finally add it into the binary. Is that something for which there are existing tools I could leverage?
