I’ve been trying for a while now to make this debugger work but I’ve ran into so many problems.
At first, I was getting the same errors as in this guide, but I fixed them by downloading the drivers directly from the ESP-IDF Tools Setup. The common errors were resolved but now I’m getting this error log:
undefinedOpen On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
adapter speed: 40000 kHz
Warn : Transport "jtag" was already selected
adapter speed: 5000 kHz
Info : esp_usb_jtag: serial (48:27:E2:8F:85:40)
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 5000 kHz
Info : JTAG tap: esp32s3.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32s3.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : [esp32s3.cpu0] Debug controller was reset.
Info : [esp32s3.cpu0] Core was reset.
Info : [esp32s3.cpu1] Debug controller was reset.
Info : [esp32s3.cpu1] Core was reset.
Error: libusb_bulk_write error: LIBUSB_ERROR_PIPE
Error: libusb_get_string_descriptor_ascii() failed with 'LIBUSB_ERROR_PIPE'
Info : starting gdb server for esp32s3.cpu0 on 3333
Error: missing data from bitq interface
Error: extra data from bitq interface
Error: Failed to exec JTAG queue!
Error: Failed to read debug stubs address location (-104)!
Polling target esp32s3.cpu0 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Polling target esp32s3.cpu1 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Info : [esp32s3.cpu1] Target halted, PC=0x403770F5, debug_reason=00000001
Info : Set GDB target to 'esp32s3.cpu1'
C:\Users\lucas\.platformio\packages\toolchain-xtensa-esp32s3@8.4.0+2021r2-patch5\bin\xtensa-esp32s3-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from C:\Users\lucas\OneDrive\Documents\PlatformIO\Projects\Test\.pio\build\esp32-s3-devkitc-1\firmware.elf...
PlatformIO: debug_tool = esp-builtin
Info : [esp32s3.cpu0] Target halted, PC=0x4202025E, debug_reason=00000000
Does anyone have an idea as to what could be causing these problems ?
