I am kind of new to this platform, let me know if I have to change the location of this post.
I am currently trying a few STM32 boards and I want to migrate from Arduino IDE to VSC + Platformio.
My current problem is with the mentioned Blackpill board. It work for a while on multiple projects but suddenly I started getting this error when trying to compile.
Compiling .pio\build\blackpill_f411ce\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\blackpill_f411ce\FrameworkArduino\wiring_pulse.cpp.o
Compiling .pio\build\blackpill_f411ce\FrameworkArduino\wiring_shift.c.o
Compiling .pio\build\blackpill_f411ce\FrameworkArduino\wiring_time.c.o
Archiving .pio\build\blackpill_f411ce\libFrameworkArduino.a
Linking .pio\build\blackpill_f411ce\firmware.elf
arm-none-eabi-g++: error: F411CE: No such file or directory
arm-none-eabi-g++: error: Portenta: No such file or directory
arm-none-eabi-g++: error: Build/.pio/build/blackpill_f411ce/firmware.map: No such file or directory
*** [.pio\build\blackpill_f411ce\firmware.elf] Error 1
Thank you for the fast reply, while commenting the wrong line in the .py file didnt work, I just moved the project to a folder without spaces in the name and everything works as expected
