I have a project that uses STM32F4 Discovery and STM32Cube which I have been building using Eclipse. The project uses hard floating point. I was able to get it to build under Platformio without floating point. I added the -mfloat-abi=hard -mfpu=fpv4-sp-d16 to my build_flags to enable hard floating point. When I did this I got an error in linking. I looked at the eclipse link and found that these flags need to be passed to the arm-none-eabi-g++ command the performs the link. I tried doing this using the -Wl option, but the -Wl option is retained and arm-none-eabi-g++ needs the option with the -Wl.
To get it to work I finally edited stm32cube.py to add the flags to both the compiler (for convenience) and linker:
CCFLAGS=[
"-Os", # optimize for size
"-ffunction-sections", # place each function in its own section
"-fdata-sections",
"-Wall",
"-mthumb",
"-mfloat-abi=hard",
"-mfpu=fpv4-sp-d16",
"-mcpu=%s" % env.BoardConfig().get("build.cpu"),
"-nostdlib"
LINKFLAGS=[
"-Os",
"-Wl,--gc-sections,--relax",
"-mthumb",
"-mfloat-abi=hard",
"--specs=nano.specs",
"--specs=nosys.specs"
