Basically all done per docs and some scripting. Compilation works
RAM: [== ] 23.1% (used 3788 bytes from 16384 bytes)
Flash: [===== ] 52.7% (used 69096 bytes from 131072 bytes)
Building .pio\build\lpc2134_01\firmware.bin
====================== [SUCCESS] Took 3.28 seconds ======================
And uploading works with precompiled lpc21isp programs for, provided for Window and Linux. So a PlatformIO “Upload” will trigger the exact same thing as a make flash in the original repo you linked.
Thanks, I wasn’t using GitHub linkage, just downloading a zip copy, I have now added GitHub extensions etc. pulled it down and it builds OK.
Fantastic work thank you.
I will not be able to check for a bit as I need a new USB-UART converter - all mine are hard wired to 5V but the LPC is 3V3 so I am waiting for one to turn up, possibly mid-week, if later I will be away for a week so it will go on hold unfortunately.
So the converter arrived today, and it loaded perfectly!
Awesome work!
Thank you very much.
BTW, someone is struggling to build the .hex files, I had no problem but he is - GitLang - he responded to my question Re. building in VScode - issue 206 on the main GitHub page for this code, I was of little help for him!
