Hi ,
I want to build a specific file on the src folder apart from the main.cpp and create the binary in pio build folder.
If the specific file is abc.cpp ,
I tried to use the method mentioned in -
my .ini is ;
[env]
platform = ststm32
board = nucleo_f767zi
upload_protocol = serial
monitor_speed = 921600
test_framework = unity
board_build.ldscript = ldscript.ld
-DARDUINOJSON_USE_DOUBLE=1
-DMBEDTLS_CONFIG_FILE=\"include\\mbedtls_config.h\"
-DFLASH_BASE_ADDRESS=0x08018000
-DFLASH_DATA_SECTOR=3
-I.
-Iinclude
-DWOLFBOOT_HASH_SHA256=1
-DHSE_VALUE=12000000U
bblanchon/ArduinoJson@^6.17.2
densaugeo/base64@^1.2.0
arduino-libraries/ArduinoECCX08@^1.3.5
SparkFun u-blox GNSS Arduino Library@^2.0.15
SPI
extra_scripts =
pre:scripts/firmware-name.py
[development]
-DABC_PROJECT_ID=\"abc-dev\"
test_filter = test_eng
[production]
-w
-DABC_PROJECT_ID=\"abcproj-208715\"
test_filter = test_mfg
[env:abc]
platform = ststm32
build_src_filter = "+<abc.cpp>"
and I used “pio run -e abc”
Doesn’t seems like compiling the specific file, also compiles all the libraries in lib_deps which use in main.cpp and not necessary for abc.cpp and giving errors .
My abc.cpp file that I want to build is -
# include <Arduino.h>
# define BOOT_MODE PB12
void setup()
// Setup and Initialize serial for debug
// Initializing the bootloader pin
pinMode(BOOT_MODE, OUTPUT);
digitalWrite(BOOT_MODE, LOW);
void loop()
if (Serial.available() > 0)
String incomingData = Serial.readString();
if (incomingData == "boot")
digitalWrite(BOOT_MODE, HIGH);
delay(250);
NVIC_SystemReset();
Appreciate if someone can help me with this issue .
Thank,
Sam.
