Build problem after reinstallation
Had to reinstall on a new mashine … got build error:
PackageManager: Installing framework-arduinoespressif8266 @ 2.20402.4-puya
Error: Could not find a version that satisfies the requirement '2.20402.4-puya' for your system 'windows_amd64'
any idea?
Running core 3.6.7
What’s your platformio.ini look like? Any idea why it’s looking for 2.20402.4-puya rather than 2.20402.4?
It happens when I start a new Projekt:
[env:d1_mini]
platform = espressif8266
board = d1_mini
But the issue started when I was trying to buld “ESPeasy” latest version.
ESPEasy @ github
Think the issue is located there
I suspect so - I’m not sure what ESPEasy changed that manage to stuff that up though…, unless it’s a glitch in PIO in relation to existing platform files. I’ll try it out later when I’m back on my development system… might be just a matter of deleting the puya folder, and letting the regular one install first.
This was a ESPEasy related problem and it is solved now (had something to do with an SSL certificate not working as expected). Thank you for your help!
Thanks for the update… good to see it was resolved :slight_smile:
