Currently I work on a project that runs on an ESP32 with the Arduino framework. Next to the main sources, I have have some tools for validating components, sensors and actuators that also run on ESP32. I want to add unit tests using ‘native’ for some algorithms that don’t directly interface to the hardware.
This is where it gets interesting. I can run the tools using pio run -e i2c_scan for the ESP32 using the ‘build_source_filter’ and the extends keyword.
But if I want to run the tests, I still need to do pio test -e native
Is it possible to let pio test to only run the ‘native’ environment?
What would be the best way to split the tests into native ones and those that run inline on the ESP32?
My platformio.ini file looks like this:
[platformio]
default_envs = house2
[esp32]
board = nodemcu-32s
upload_port = /dev/ttyUSB0
monitor_port = /dev/ttyUSB0
budryerson/TFLI2C@^0.2.0
adafruit/Adafruit PWM Servo Driver Library@^2.4.1
robtillaart/MCP23017@^0.2.6
sparkfun/SparkFun VL53L1X 4m Laser Distance Sensor@^1.2.11
[env:house2]
extends = esp32
[env:native]
platform = native
-D UNITY_INT_WIDTH=32
[env:io_extender]
extends = esp32
build_src_filter = +<../tools/io_extender/io_extender.cpp>
[env:i2c_scan]
extends = esp32
build_src_filter = +<../tools/i2c_scan/i2c_scan.cpp>
[env:luna_config]
extends = esp32
build_src_filter = +<../tools/luna_config/luna_config.cpp>
[env:servoshield]
extends = esp32
build_src_filter = +<../tools/servoshield/servoshield.cpp>
[env:i2c_distance]
extends = esp32
build_src_filter = +<../tools/i2c_distance/i2c_distance.cpp>
[env:luna_array]
extends = esp32
build_src_filter = +<../tools/luna_array/luna_array.cpp>
[env:status_leds]
extends = esp32
build_src_filter = +<../tools/status_leds/status_leds.cpp>
Full project is here:
