Hi, I am new here. I have a problem when using the PlatformIO IDE, hope could get some help here.
Here is the problem:
I am trying to use the VScode +PlatformIO to build the Marlin 2.0 firmware, but the build process always show me the error “Error: Could not find the package with ‘framework-arduino-lpc176x @ 0.1.3’ requirements for your system ‘windows_amd64’”
I downloaded the 0.1.3 framework-arduino-lpc176x package and put it under the .platformio\platforms path, restart the VScode, does not work.
Thanks for any help.
Are you using the latest Marlin code base? There were changes that needed to be done regarding PIO core 5 which only allows package installation from the trusted PlatformIO repository.
Also see thread at Marlin: Help me ERRROR ModuleNotFoundError - #11 by maxgerhardt.
Thanks, man!! I tried the latest 2.0.6.1 once but failed so I give it up. After reading your post, I downloaded the 2.0.6.1 and it worked this time.
Thanks a lot!!
I have BTT skr v1.3 board and wanted to flash update with newer Marlin 2.0.x, Board been flashed with pre-configured .bin file from Github. It prints fine but off center. I downloaded most recent Marlin and transferred Configuration H and adv from Tronxy Marlin file that I downloaded from Github… In Marlin-platformio.ini file, I already put in default_envs = lpc176x for board. Compiled and it show "framework-ardurino-lpc176x… error. Bottom line is that I wanted to center the Nozzle… I can’t figure it out what I did wrong. Suggestion?
