I was following the docs on https://espressif-docs.readthedocs-hosted.com/_/downloads/esp8266-rtos-sdk/en/v3.2/pdf/ to get used to ther board. but every time i try to use the esp_get_idf_version() or others esp_system.h function i got errors on my build.
when i try to build the project_template i got
Linking .pio\build\d1_mini\firmware.elf
.pio\build\d1_mini\src\user_main.o:(.text.user_init+0x4): undefined reference to `esp_get_idf_version'
.pio\build\d1_mini\src\user_main.o: In function `user_init':
user_main.c:(.text.user_init+0xe): undefined reference to `esp_get_idf_version'
*** [.pio\build\d1_mini\firmware.elf] Error 1
my wsl version is 1 and i am using the corresponding port ttyS5(COM5)
How can i fix it? when i build with make using ubuntu wsl it works
