First off: I am new to PlatformIO. I have done little with it and am working on my first serious project using it.
The issue I am having is that, while using PlatformIO in VS Code on a ESP32 Dev Kit C V4 board and Arduino framework, the code builds differently based on the name that I give the environment. Why is this? Should I be concerned about the device operating differently, or is it simply that there are non-functional values that change in built code (e.g. a version/platform string only used for viewing purposes)?
I can provide other detailed information if it helps, but for now, here’s the build output spit out to the terminal:
env name 1
> Executing task in folder amway_biozoom_proto1: C:\Users\tpars\.platformio\penv\Scripts\platformio.exe run <
Processing esp32doit-devkit-v1 (platform: espressif32; board: az-delivery-devkit-v4; framework: arduino)
None
CONFIGURATION: docs.platformio.org/page/boards/espressif32/az-delivery-devkit-v4.html
PLATFORM: Espressif 32 1.11.2 > AZ-Delivery ESP-32 Dev Kit C V4
HARDWARE: ESP32 240MHz, 520KB RAM, 16MB Flash
LDF: Library Dependency Finder -> bit.ly/configure-pio-ldf
Found 33 compatible libraries
|-- <ArduinoJson> 6.14.1 #9cb0ddb
|-- <OneButton> #c865132
|-- <ESP Async WebServer> 1.2.3
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <Ticker> 1.1
|-- <Update> 1.0
|-- <WiFi> 1.0
|-- <crc>
|-- <Base64Writer> 0.0.1
|-- <DNSServer> 1.1.0
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.0
|-- <PString>
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
|-- <WebServer> 1.0
| |-- <WiFi> 1.0
| |-- <FS> 1.0
Compiling .pio\build\esp32doit-devkit-v1\src\BiozoomWebServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\src\biozoom_comm.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Generating partitions .pio\build\esp32doit-devkit-v1\partitions.bin
Archiving .pio\build\esp32doit-devkit-v1\lib779\libArduinoJson.a
Indexing .pio\build\esp32doit-devkit-v1\lib779\libArduinoJson.a
Compiling .pio\build\esp32doit-devkit-v1\lib2fc\OneButton\OneButton.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib3ff\AsyncTCP_ID1826\AsyncTCP.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib3be\FS\FS.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib3be\FS\vfs_api.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\ETH.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiGeneric.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib2fc\libOneButton.a
Indexing .pio\build\esp32doit-devkit-v1\lib2fc\libOneButton.a
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiScan.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib3ff\libAsyncTCP_ID1826.a
Archiving .pio\build\esp32doit-devkit-v1\lib3be\libFS.a
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiServer.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\lib3ff\libAsyncTCP_ID1826.a
Indexing .pio\build\esp32doit-devkit-v1\lib3be\libFS.a
Compiling .pio\build\esp32doit-devkit-v1\libf1a\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\AsyncEventSource.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\AsyncWebSocket.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\SPIFFSEditor.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\WebAuthentication.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\WebHandlers.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\WebRequest.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\WebResponses.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\liba1e\ESP Async WebServer_ID306\WebServer.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\libf1a\libWiFi.a
Compiling .pio\build\esp32doit-devkit-v1\lib32b\Ticker\Ticker.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\libf1a\libWiFi.a
Compiling .pio\build\esp32doit-devkit-v1\lib54f\Update\Updater.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib32b\libTicker.a
Compiling .pio\build\esp32doit-devkit-v1\lib9ab\crc\crc.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\lib32b\libTicker.a
Compiling .pio\build\esp32doit-devkit-v1\lib179\Base64Writer\Base64Writer.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib9ab\libcrc.a
Indexing .pio\build\esp32doit-devkit-v1\lib9ab\libcrc.a
Compiling .pio\build\esp32doit-devkit-v1\libc67\DNSServer\DNSServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib0d6\ESPmDNS\ESPmDNS.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib8ae\WiFiClientSecure\WiFiClientSecure.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib54f\libUpdate.a
Archiving .pio\build\esp32doit-devkit-v1\lib179\libBase64Writer.a
Indexing .pio\build\esp32doit-devkit-v1\lib179\libBase64Writer.a
Indexing .pio\build\esp32doit-devkit-v1\lib54f\libUpdate.a
Compiling .pio\build\esp32doit-devkit-v1\lib8ae\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\libf8e\HTTPClient\HTTPClient.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\libc67\libDNSServer.a
Compiling .pio\build\esp32doit-devkit-v1\lib768\PString\PString.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\libc67\libDNSServer.a
Compiling .pio\build\esp32doit-devkit-v1\lib5ee\SPIFFS\SPIFFS.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib627\WebServer\Parsing.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib0d6\libESPmDNS.a
Archiving .pio\build\esp32doit-devkit-v1\lib768\libPString.a
Compiling .pio\build\esp32doit-devkit-v1\lib627\WebServer\WebServer.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib627\WebServer\detail\mimetable.cpp.o
Indexing .pio\build\esp32doit-devkit-v1\lib768\libPString.a
Indexing .pio\build\esp32doit-devkit-v1\lib0d6\libESPmDNS.a
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
Indexing .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\MD5Builder.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib8ae\libWiFiClientSecure.a
Indexing .pio\build\esp32doit-devkit-v1\lib8ae\libWiFiClientSecure.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Print.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\lib5ee\libSPIFFS.a
Indexing .pio\build\esp32doit-devkit-v1\lib5ee\libSPIFFS.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\StreamString.cpp.o
Archiving .pio\build\esp32doit-devkit-v1\libf8e\libHTTPClient.a
Indexing .pio\build\esp32doit-devkit-v1\libf8e\libHTTPClient.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-i2c.c.o
Archiving .pio\build\esp32doit-devkit-v1\lib627\libWebServer.a
Indexing .pio\build\esp32doit-devkit-v1\lib627\libWebServer.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-uart.c.o
Archiving .pio\build\esp32doit-devkit-v1\liba1e\libESP Async WebServer_ID306.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\wiring_pulse.c.o
Indexing .pio\build\esp32doit-devkit-v1\liba1e\libESP Async WebServer_ID306.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduino.a
Indexing .pio\build\esp32doit-devkit-v1\libFrameworkArduino.a
Linking .pio\build\esp32doit-devkit-v1\firmware_1.0.102.elf
Building .pio\build\esp32doit-devkit-v1\firmware_1.0.102.bin
Retrieving maximum program size .pio\build\esp32doit-devkit-v1\firmware_1.0.102.elf
Checking size .pio\build\esp32doit-devkit-v1\firmware_1.0.102.elf
RAM: [= ] 8.8% (used 46864 bytes from 532480 bytes)
Flash: [========= ] 92.3% (used 1209401 bytes from 1310720 bytes)
esptool.py v2.6
env name 2
Processing jlink_debug (platform: espressif32; board: az-delivery-devkit-v4; framework: arduino)
None
CONFIGURATION: same
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <Ticker> 1.1
|-- <Update> 1.0
|-- <WiFi> 1.0
|-- <crc>
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.0
| | |-- <WiFi> 1.0
|-- <PString>
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
|-- <WebServer> 1.0
| |-- <WiFi> 1.0
| |-- <FS> 1.0
Compiling .pio\build\jlink_debug\src\BiozoomWebServer.cpp.o
Compiling .pio\build\jlink_debug\src\biozoom_comm.cpp.o
Compiling .pio\build\jlink_debug\src\main.cpp.o
Generating partitions .pio\build\jlink_debug\partitions.bin
Archiving .pio\build\jlink_debug\liba19\libArduinoJson.a
Indexing .pio\build\jlink_debug\liba19\libArduinoJson.a
Compiling .pio\build\jlink_debug\liba70\OneButton\OneButton.cpp.o
Compiling .pio\build\jlink_debug\lib474\AsyncTCP_ID1826\AsyncTCP.cpp.o
Compiling .pio\build\jlink_debug\lib3be\FS\FS.cpp.o
Compiling .pio\build\jlink_debug\lib3be\FS\vfs_api.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\ETH.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFi.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiAP.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiClient.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiGeneric.cpp.o
Archiving .pio\build\jlink_debug\liba70\libOneButton.a
Indexing .pio\build\jlink_debug\liba70\libOneButton.a
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiScan.cpp.o
Archiving .pio\build\jlink_debug\lib3be\libFS.a
Indexing .pio\build\jlink_debug\lib3be\libFS.a
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiServer.cpp.o
Compiling .pio\build\jlink_debug\libf1a\WiFi\WiFiUdp.cpp.o
Archiving .pio\build\jlink_debug\lib474\libAsyncTCP_ID1826.a
Indexing .pio\build\jlink_debug\lib474\libAsyncTCP_ID1826.a
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\AsyncEventSource.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\AsyncWebSocket.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\SPIFFSEditor.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\WebAuthentication.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\WebHandlers.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\WebRequest.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\WebResponses.cpp.o
Compiling .pio\build\jlink_debug\lib8cb\ESP Async WebServer_ID306\WebServer.cpp.o
Compiling .pio\build\jlink_debug\lib32b\Ticker\Ticker.cpp.o
Archiving .pio\build\jlink_debug\libf1a\libWiFi.a
Indexing .pio\build\jlink_debug\libf1a\libWiFi.a
Archiving .pio\build\jlink_debug\lib32b\libTicker.a
Indexing .pio\build\jlink_debug\lib32b\libTicker.a
Compiling .pio\build\jlink_debug\lib54f\Update\Updater.cpp.o
Compiling .pio\build\jlink_debug\lib9ab\crc\crc.cpp.o
Compiling .pio\build\jlink_debug\lib179\Base64Writer\Base64Writer.cpp.o
Compiling .pio\build\jlink_debug\libc67\DNSServer\DNSServer.cpp.o
Archiving .pio\build\jlink_debug\lib9ab\libcrc.a
Indexing .pio\build\jlink_debug\lib9ab\libcrc.a
Compiling .pio\build\jlink_debug\lib0d6\ESPmDNS\ESPmDNS.cpp.o
Compiling .pio\build\jlink_debug\lib8ae\WiFiClientSecure\WiFiClientSecure.cpp.o
Archiving .pio\build\jlink_debug\lib54f\libUpdate.a
Archiving .pio\build\jlink_debug\lib179\libBase64Writer.a
Indexing .pio\build\jlink_debug\lib54f\libUpdate.a
Indexing .pio\build\jlink_debug\lib179\libBase64Writer.a
Compiling .pio\build\jlink_debug\lib8ae\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\jlink_debug\libf8e\HTTPClient\HTTPClient.cpp.o
Archiving .pio\build\jlink_debug\libc67\libDNSServer.a
Compiling .pio\build\jlink_debug\lib768\PString\PString.cpp.o
Indexing .pio\build\jlink_debug\libc67\libDNSServer.a
Compiling .pio\build\jlink_debug\lib5ee\SPIFFS\SPIFFS.cpp.o
Compiling .pio\build\jlink_debug\lib627\WebServer\Parsing.cpp.o
Archiving .pio\build\jlink_debug\lib0d6\libESPmDNS.a
Archiving .pio\build\jlink_debug\lib768\libPString.a
Compiling .pio\build\jlink_debug\lib627\WebServer\WebServer.cpp.o
Compiling .pio\build\jlink_debug\lib627\WebServer\detail\mimetable.cpp.o
Indexing .pio\build\jlink_debug\lib768\libPString.a
Indexing .pio\build\jlink_debug\lib0d6\libESPmDNS.a
Archiving .pio\build\jlink_debug\libFrameworkArduinoVariant.a
Indexing .pio\build\jlink_debug\libFrameworkArduinoVariant.a
Compiling .pio\build\jlink_debug\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\MD5Builder.cpp.o
Archiving .pio\build\jlink_debug\lib8ae\libWiFiClientSecure.a
Indexing .pio\build\jlink_debug\lib8ae\libWiFiClientSecure.a
Compiling .pio\build\jlink_debug\FrameworkArduino\Print.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\Stream.cpp.o
Archiving .pio\build\jlink_debug\lib5ee\libSPIFFS.a
Indexing .pio\build\jlink_debug\lib5ee\libSPIFFS.a
Compiling .pio\build\jlink_debug\FrameworkArduino\StreamString.cpp.o
Archiving .pio\build\jlink_debug\libf8e\libHTTPClient.a
Indexing .pio\build\jlink_debug\libf8e\libHTTPClient.a
Compiling .pio\build\jlink_debug\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\WString.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\base64.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-matrix.c.o
Archiving .pio\build\jlink_debug\lib627\libWebServer.a
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-psram.c.o
Indexing .pio\build\jlink_debug\lib627\libWebServer.a
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\libb64\cencode.c.o
Archiving .pio\build\jlink_debug\lib8cb\libESP Async WebServer_ID306.a
Compiling .pio\build\jlink_debug\FrameworkArduino\main.cpp.o
Compiling .pio\build\jlink_debug\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\jlink_debug\FrameworkArduino\wiring_pulse.c.o
Indexing .pio\build\jlink_debug\lib8cb\libESP Async WebServer_ID306.a
Compiling .pio\build\jlink_debug\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\jlink_debug\libFrameworkArduino.a
Indexing .pio\build\jlink_debug\libFrameworkArduino.a
Linking .pio\build\jlink_debug\firmware_1.0.102.elf
Building .pio\build\jlink_debug\firmware_1.0.102.bin
Retrieving maximum program size .pio\build\jlink_debug\firmware_1.0.102.elf
Checking size .pio\build\jlink_debug\firmware_1.0.102.elf
Flash: [========= ] 92.3% (used 1209393 bytes from 1310720 bytes)
esptool.py v2.6
