Well, I’ll have a bash at a reply, but I might not be completely correct! (Given the layout of your project, I’m more of an Uno man myself!)
For the main project, header files can live in src or include. Both are searched automatically at compile time without any further action on your part, as are any directories added using build_flags -I ....
For a library named “XXX”, there will be a directory, lib/XXX and in there, all the headers and sources for that particular library. When building a library, as part of a project build, only the particular library will be searched for headers. The src and include directories are not scanned. Other directories added with build_flags will be scanned.
If you have header files that you want to have included in the project, or library compilations, which do not live in the project itself, then, add the directory/directories they live in to the build_flags in platformio.ini.
Lets say you have headers in SourceCode/headers then your build_flags will look like:
-I SourceCode/headers
In your project, or libraries, to include SourceCode/headers/myHeader.h you simply #include "myHeader.h" and it will be found.
Example:
- I have a header file,
my_duino.h which lives in /home/norman/SourceCode/headers/. This header reads Arduino.h and defines a macro, TOGGLE_LED, which maps onto a function, in the asm library, named toggle().
- I have a library, for want of a better word, named
asm, which is located in lib/asm under my project. The library contains:
- A header file,
asm.h whgich defines the prototypes for two functions, setup() and toggle().
- A source file, in assembly, named
asm.S which has the source for the setup() and toggle() functions.
The files are:
platformio.ini
[env:uno]
board = uno
-I /home/norman/SourceCode/headers
main.cpp
// This header is in SourceCode/headers/.
#include "my_duino.h"
// This header is in lib/asm
#include "asm.h"
// setup() is called from the assembly code.
// And is not shown here.
// Loop simply calls toggle(), via TOGGLE_LED(), to toggle
// the LED.
TOGGLE_LED();
delay(1000);
lib/asm/asm.h
#ifndef ASM_H
#define ASM_H
extern "C" {
void setup();
void toggle();
lib/asm/asm.S
#define __SFR_OFFSET 0
#include <avr/io.h>
.section .text
.global setup
.global toggle
setup:
ldi r16,(1 << DDB5)
out DDRB,r16
ret
toggle:
ldi r16,(1 << DDB5)
out PINB,r16
ret
SourceCode/headers/my_duino.h
#ifndef MYDUINO_H
#define MYDUINO_H
// The main.cpp needs this header always. At least when
// using the arduino framework that is!
// A silly example to get something usable from this header.
#define TOGGLE_LED() toggle()
I have #included the header file which is out of the project structure, SourceCode.headers/my_duino.h and the header file from the library, lib/asm/asm.h, simply by using their terminal names. The platformio.ini file tells the compiler where to find the additional header that is out of the project structure, and the compiler knows to search in the library’s directory when compiling the library.
If you run a verbose compilation, you get these options passed for headers etc.
Compiling main.cpp
avr-g++ ... -Iinclude -Isrc -Ilib/asm -I/home/norman/SourceCode/headers ...
Here you can see that src and include in the project structure are scanned, and also the directory added using build_flags and the asm library source folder too.
Compiling lib/asm/asm.S
avr-gcc ... -Ilib/asm -I/home/norman/SourceCode/headers ...
Here you can see that src and include in the project structure are not scanned, only the directory added using build_flags and the asm library source folder too.
HTH
Cheers,
Norm.
