since this moring (with no code changes) the build of my project failed in the python code. here is the traceback
PLATFORM: Espressif 32 (4.3.0) > Espressif ESP32 Dev Module
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.0 (2.0.3)
KeyError: 'IDE_EXTRA_DATA':
File "C:\Users\Save_\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 188:
File "C:\Users\Save_\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Script\SConscript.py", line 597:
File "C:\Users\Save_\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Script\SConscript.py", line 285:
File "C:\Users\Save_\.platformio\platforms\espressif32\builder\main.py", line 287:
File "C:\Users\Save_\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Util.py", line 737:
File "C:\Users\Save_\.platformio\penv\lib\site-packages\platformio\builder\tools\piobuild.py", line 60:
env.ProcessProgramDeps()
File "C:\Users\Save_\.platformio\penv\lib\site-packages\platformio\builder\tools\piobuild.py", line 120:
File "C:\Users\Save_\.platformio\penv\lib\site-packages\platformio\builder\tools\piobuild.py", line 326:
SConscript(env.GetFrameworkScript(name), exports="env")
File "C:\Users\Save_\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Script\SConscript.py", line 660:
return method(*args, **kw)
File "C:\Users\Save_\.platformio\platforms\espressif32\builder\frameworks\arduino.py", line 44:
env["IDE_EXTRA_DATA"].update({"application_offset": env.subst("$ESP32_APP_OFFSET")})
File "C:\Users\Save_\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Environment.py", line 387:
return self._dict[key]
This happens with ESP32 only as far as i can see. RP2040 compiles with no problem.
here is my platformio.ini config
[env:BOARD_ESP32]
platform = espressif32@4.3.0
this seems to not happen with platform = espressif32@5.1.0
i think this is a backward compatibility problem.
