Build error with AsyncTCP
Hi. Noob here, making first steps, or not so much. I’m trying to build for ESP32-S3 but the build fails. I have the same 2 libraries work in Arduino IDE but not in PlatformIO. Any idea why? I found some similar issue here on the forum but it was about using the wrong libraries (for ESP2866 instead of ESP32), but I believe I got the right ones.
Processing freenove_esp32_s3_wroom (platform: espressif32; board: freenove_esp32_s3_wroom; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/freenove_esp32_s3_wroom.html
PLATFORM: Espressif 32 (6.12.0) > Freenove ESP32-S3 WROOM N8R8 (8MB Flash / 8MB PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
 - tool-esptoolpy @ 2.40900.250804 (4.9.0)
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Found 39 compatible libraries
|-- AsyncTCP @ 3.3.8
|-- ESPAsyncWebServer @ 3.7.4
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\RPAsyncTCP.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\AsyncPrinter.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\ESPAsyncTCP.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\ESPAsyncTCPbuffer.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\SyncClient.cpp.o
C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/RPAsyncTCP.cpp: In member function 'bool AsyncClient::connect(IPAddress, uint16_t)':
C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/RPAsyncTCP.cpp:231:8: error: 'ip_addr_t' {aka 'struct ip_addr'} has no member named 'addr'; did you mean 'u_addr'?
   addr.addr = ip;
        u_addr
In the ArduinoIDE you will probably have the latest Espressif32 Arduino Framework 3.x.
To get this in PlatformIO you have to use pioarduino’s fork of the Espressif32 platform.
Edit your platformio.ini and change the platform setting:
For more details about the espressif32 platform versions take a look at this list.
Thank you, but still not working ;(
Executing task in folder sbx Platformio: C:\Users\xxxx\.platformio\penv\Scripts\platformio.exe run --environment freenove_esp32_s3_wroom
Processing freenove_esp32_s3_wroom (platform: https://github.com/pioarduino/platform-espressif32/releases/download/stable/platform-espressif32.zip; board: freenove_esp32_s3_wroom; framework: arduino)
PLATFORM: Espressif 32 (55.3.33) > Freenove ESP32-S3 WROOM N8R8 (8MB Flash / 8MB PSRAM)
 - contrib-piohome @ 3.4.4
 - framework-arduinoespressif32 @ 3.3.3
 - framework-arduinoespressif32-libs @ 5.5.0+sha.f1a1df9b2e
 - tool-esptoolpy @ 5.1.0
 - tool-mklittlefs @ 3.2.0
 - toolchain-xtensa-esp-elf @ 14.2.0+20250730
*** Applied include path shortening for 330 framework paths ***
*** Path length reduced from 39028 to ~13711 characters ***
*** Estimated savings: 24750 characters ***
Found 49 compatible libraries
|-- AsyncTCP @ 3.4.9
|-- ESPAsyncWebServer @ 3.8.1
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\AsyncPrinter.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\RPAsyncTCP_buffer.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\SyncClient.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\Parsing.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\WebServer.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\detail\mimetable.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\middleware\AuthenticationMiddleware.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\middleware\CorsMiddleware.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\middleware\LoggingMiddleware.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\middleware\MiddlewareChain.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib9d1\ESPAsyncWebServer\AsyncEventSource.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib9d1\ESPAsyncWebServer\AsyncJson.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib9d1\ESPAsyncWebServer\AsyncMessagePack.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib9d1\ESPAsyncWebServer\AsyncWebHeader.cpp.o
In file included from C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiSTA.h:30,
                 from C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFi.h:34,
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/RPAsyncTCP.h:5,
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/AsyncPrinter.h:26,
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/AsyncPrinter.cpp:26:
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiGeneric.h:44:10: fatal error: Network.h: No such file or directory
* Looking for Network.h dependency? Check our library registry!
* CLI  > platformio lib search "header:Network.h"
* Web  > https://registry.platformio.org/search?q=header:Network.h
Please show the content of your platformio.ini
platfomio.ini
[env:freenove_esp32_s3_wroom]
board = freenove_esp32_s3_wroom
	esp32async/ESPAsyncWebServer@^3.8.1
	esp32async/AsyncTCP@^3.4.9
Build
|-- AsyncTCP @ 3.4.9
Compiling .pio\build\freenove_esp32_s3_wroom\lib164\Hash\PBKDF2_HMACBuilder.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib164\Hash\SHA1Builder.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib164\Hash\SHA2Builder.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib164\Hash\SHA3Builder.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\cbuf.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\debug.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\tcp_axtls.c.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib33e\Network\NetworkClient.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib33e\Network\NetworkEvents.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib33e\Network\NetworkInterface.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib33e\Network\NetworkManager.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib33e\Network\NetworkServer.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib33e\Network\NetworkUdp.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\AP.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\STA.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\WiFi.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\WiFiAP.cpp.o
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/SyncClient.cpp:7:
   44 | #include "Network.h"
compilation terminated.
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/RPAsyncTCP.cpp:7:
*** [.pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\SyncClient.cpp.o] Error 1
*** [.pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\RPAsyncTCP.cpp.o] Error 1
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/RPAsyncTCP_buffer.h:11,
                 from C:/Users/xxxx/.platformio/lib/RPAsyncTCP/src/RPAsyncTCP_buffer.cpp:8:
*** [.pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\AsyncPrinter.cpp.o] Error 1
*** [.pio\build\freenove_esp32_s3_wroom\lib3f1\RPAsyncTCP\RPAsyncTCP_buffer.cpp.o] Error 1
========================================= [FAILED] Took 13.39 seconds =========================================
 *  The terminal process "C:\Users\xxxx\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'freenove_esp32_s3_wroom'" terminated with exit code: 1.
Remove this form your platformio.ini. AsyncTCP is a dependency of ESPAsyncWebServer. The correct version will be installed automatically.
It looks like your framework / platform files are broken.
  • Close VS Code
  • Delete the folder C:/Users/xxxx/.platformio/packages
  • Delete the folder C:/Users/xxxx/.platformio/platforms
  • Restart VS Code
  • Wait until PlatformIO installed all missing files and build the project again
Hi @sivar2311 I really apriciate you trying to help me. Unfortunatelly, I still keep getting errors ;(
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\libcab\WiFi\WiFiScan.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib25b\AsyncTCP\AsyncTCP.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\tcp_axtls.c.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib0a3\FS\FS.cpp.o
Compiling .pio\build\freenove_esp32_s3_wroom\lib0a3\FS\vfs_api.cpp.o
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCPbuffer.cpp:27:10: fatal error: debug.h: No such file or directory
* Looking for debug.h dependency? Check our library registry!
* CLI  > platformio lib search "header:debug.h"
* Web  > https://registry.platformio.org/search?q=header:debug.h
   27 | #include <debug.h>
*** [.pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\ESPAsyncTCPbuffer.cpp.o] Error 1
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/libraries/WebServer/src/Parsing.cpp:24:10: fatal error: NetworkServer.h: No such file or directory
* Looking for NetworkServer.h dependency? Check our library registry!
* CLI  > platformio lib search "header:NetworkServer.h"
* Web  > https://registry.platformio.org/search?q=header:NetworkServer.h
   24 | #include "NetworkServer.h"
*** [.pio\build\freenove_esp32_s3_wroom\libc0d\WebServer\Parsing.cpp.o] Error 1
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/SyncClient.cpp:25:10: fatal error: interrupts.h: No such file or directory
* Looking for interrupts.h dependency? Check our library registry!
* CLI  > platformio lib search "header:interrupts.h"
* Web  > https://registry.platformio.org/search?q=header:interrupts.h
   25 | #include <interrupts.h>
*** [.pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\SyncClient.cpp.o] Error 1
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp: In constructor 'AsyncPrinter::AsyncPrinter(AsyncClient*, size_t)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp:48:5: error: 'panic' was not declared in this scope
   48 |     panic(); //What should we do?
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp: In member function 'int AsyncPrinter::connect(IPAddress, uint16_t)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp:71:5: error: 'panic' was not declared in this scope
   71 |     panic();
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp: In member function 'int AsyncPrinter::connect(const char*, uint16_t)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp:88:5: error: 'panic' was not declared in this scope
   88 |     panic();
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp: In member function 'void AsyncPrinter::_onConnect(AsyncClient*)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp:109:5: error: 'panic' was not declared in this scope
  109 |     panic();
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp: In member function 'AsyncPrinter& AsyncPrinter::operator=(const AsyncPrinter&)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp:130:5: error: 'panic' was not declared in this scope
  130 |     panic();
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp: In member function 'size_t AsyncPrinter::_sendBuffer()':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/AsyncPrinter.cpp:182:5: error: 'panic' was not declared in this scope
  182 |     panic(); // Connection should be aborted instead
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp: In member function 'bool AsyncClient::connect(IPAddress, uint16_t)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:267:33: error: invalid user-defined conversion from 'IPAddress' to 'const ip_addr_t*' {aka 'const ip_addr*'} [-fpermissive]
  267 |   size_t err = tcp_connect(pcb, addr, port,(tcp_connected_fn)&_s_connected);
In file included from C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:198,
                 from C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:74:
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:83:3: note: candidate is: 'IPAddress::operator uint32_t() const' (near match)
   83 |   operator uint32_t() const {
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:83:3: note:   no known conversion from 'uint32_t' {aka 'long unsigned int'} to 'const ip_addr_t*' {aka 'const ip_addr*'}
In file included from C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:79:
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/include/lwip/lwip/src/include/lwip/tcp.h:461:69: note:   initializing argument 2 of 'err_t tcp_connect(tcp_pcb*, const ip_addr_t*, u16_t, tcp_connected_fn)'
  461 | err_t            tcp_connect (struct tcp_pcb *pcb, const ip_addr_t *ipaddr,
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp: In member function 'bool AsyncClient::connect(const char*, uint16_t)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:277:39: error: invalid user-defined conversion from 'IPAddress' to 'ip_addr_t*' {aka 'ip_addr*'} [-fpermissive]
  277 |   err_t err = dns_gethostbyname(host, addr, (dns_found_callback)&_s_dns_found, this);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:83:3: note:   no known conversion from 'uint32_t' {aka 'long unsigned int'} to 'ip_addr_t*' {aka 'ip_addr*'}
In file included from C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:81:
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/include/lwip/lwip/src/include/lwip/dns.h:109:69: note:   initializing argument 2 of 'err_t dns_gethostbyname(const char*, ip_addr_t*, dns_found_callback, void*)'
  109 | err_t            dns_gethostbyname(const char *hostname, ip_addr_t *addr,
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp: In member function 'bool AsyncClient::operator==(const AsyncClient&)':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:331:75: error: no matching function for call to 'IPAddress::IPAddress(ip_addr_t&)'
  331 |   return (_pcb != NULL && other._pcb != NULL && (IPAddress(_pcb->remote_ip) ==  IPAddress(other._pcb->remote_ip)) && (_pcb->remote_port == other._pcb->remote_port));
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:116:3: note: candidate: 'IPAddress::IPAddress(const ip_addr_t*)'
  116 |   IPAddress(const ip_addr_t *addr);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:116:30: note:   no known conversion for argument 1 from 'ip_addr_t' {aka 'ip_addr'} to 'const ip_addr_t*' {aka 'const ip_addr*'}
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:74:3: note: candidate: 'IPAddress::IPAddress(const IPAddress&)'
   74 |   IPAddress(const IPAddress &address);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:74:30: note:   no known conversion for argument 1 from 'ip_addr_t' {aka 'ip_addr'} to 'const IPAddress&'
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:73:3: note: candidate: 'IPAddress::IPAddress(const char*)'
   73 |   IPAddress(const char *address);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:73:25: note:   no known conversion for argument 1 from 'ip_addr_t' {aka 'ip_addr'} to 'const char*'
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:71:3: note: candidate: 'IPAddress::IPAddress(IPType, const uint8_t*, uint8_t)'
   71 |   IPAddress(IPType ip_type, const uint8_t *address, uint8_t z = 0);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:71:3: note:   candidate expects 3 arguments, 1 provided
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:70:3: note: candidate: 'IPAddress::IPAddress(const uint8_t*)'
   70 |   IPAddress(const uint8_t *address);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:70:28: note:   no known conversion for argument 1 from 'ip_addr_t' {aka 'ip_addr'} to 'const uint8_t*' {aka 'const unsigned char*'}
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:68:3: note: candidate: 'IPAddress::IPAddress(uint32_t)'
   68 |   IPAddress(uint32_t address);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:68:22: note:   no known conversion for argument 1 from 'ip_addr_t' {aka 'ip_addr'} to 'uint32_t' {aka 'long unsigned int'}
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:63:3: note: candidate: 'IPAddress::IPAddress(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)'
   63 |   IPAddress(
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:63:3: note:   candidate expects 17 arguments, 1 provided
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:62:3: note: candidate: 'IPAddress::IPAddress(uint8_t, uint8_t, uint8_t, uint8_t)'
   62 |   IPAddress(uint8_t first_octet, uint8_t second_octet, uint8_t third_octet, uint8_t fourth_octet);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:62:3: note:   candidate expects 4 arguments, 1 provided
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:61:3: note: candidate: 'IPAddress::IPAddress(IPType)'
   61 |   IPAddress(IPType ip_type);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:61:20: note:   no known conversion for argument 1 from 'ip_addr_t' {aka 'ip_addr'} to 'IPType'
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:60:3: note: candidate: 'IPAddress::IPAddress()'
   60 |   IPAddress();
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.h:60:3: note:   candidate expects 0 arguments, 1 provided
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:331:112: error: no matching function for call to 'IPAddress::IPAddress(ip_addr_t&)'
   63 |   IPAddress(
   60 |   IPAddress();
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp: In member function 'IPAddress AsyncClient::remoteIP()':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:861:23: error: call of overloaded 'IPAddress(int)' is ambiguous
  861 |     return IPAddress(0);
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:862:16: error: could not convert '((AsyncClient*)this)->AsyncClient::_pcb->tcp_pcb::remote_ip' from 'ip_addr_t' {aka 'ip_addr'} to 'IPAddress'
  862 |   return _pcb->remote_ip;
      |                ip_addr_t {aka ip_addr}
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp: In member function 'IPAddress AsyncClient::localIP()':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:871:23: error: call of overloaded 'IPAddress(int)' is ambiguous
  871 |     return IPAddress(0);
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:872:16: error: could not convert '((AsyncClient*)this)->AsyncClient::_pcb->tcp_pcb::local_ip' from 'ip_addr_t' {aka 'ip_addr'} to 'IPAddress'
  872 |   return _pcb->local_ip;
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp: In member function 'void AsyncServer::begin()':
C:/Users/xxxx/.platformio/lib/ESPAsyncTCP/src/ESPAsyncTCP.cpp:1128:23: error: invalid user-defined conversion from 'IPAddress' to 'const ip_addr_t*' {aka 'const ip_addr*'} [-fpermissive]
 1128 |   err = tcp_bind(pcb, local_addr, _port);
C:/Users/xxxx/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/include/lwip/lwip/src/include/lwip/tcp.h:458:69: note:   initializing argument 2 of 'err_t tcp_bind(tcp_pcb*, const ip_addr_t*, u16_t)'
  458 | err_t            tcp_bind    (struct tcp_pcb *pcb, const ip_addr_t *ipaddr,
*** [.pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\AsyncPrinter.cpp.o] Error 1
*** [.pio\build\freenove_esp32_s3_wroom\lib6a4\ESPAsyncTCP\ESPAsyncTCP.cpp.o] Error 1
================================================= [FAILED] Took 12.08 seconds =================================================
Can you share the project?
Sorry for animating this thread, but my build just randomly broke after I switching environments. I had to specifically add AsyncTCP in or PIO would use the RPI network for my ESP32 for one environment (rather than deleting it as suggested), but I simply cannot get the other environment to work.
	ESP32Async/AsyncTCP
Compiling .pio/build/client10/libd69/ESPAsyncWebServer/WebAuthentication.cpp.o
Compiling .pio/build/client10/libd69/ESPAsyncWebServer/WebHandlers.cpp.o
Compiling .pio/build/client10/libd69/ESPAsyncWebServer/WebRequest.cpp.o
/Users/uid/.platformio/packages/framework-arduinoespressif32/libraries/WebServer/src/Parsing.cpp:24:10: fatal error: NetworkServer.h: No such file or directory
*** [.pio/build/client10/libbc5/WebServer/Parsing.cpp.o] Error 1
/Users/uid/.platformio/packages/framework-arduinoespressif32/libraries/WebServer/src/WebServer.cpp:28:10: fatal error: NetworkServer.h: No such file or directory
I’ve been using this config for months now without any problems. I switched to 55.03.37 and back to .35 without any change. I’ve deleted both .pio and .platformio without any change.
More importantly, when I click on this file in error, it takes me to the line and I click on the header file and it opens without a problem. So intellisense knows where the files are but the compiler does not. How is that possible?
Here’s my platform.ini:
[platformio]
default_envs = client10
[env]
#platform = https://github.com/pioarduino/platform-espressif32/releases/download/55.03.37/platform-espressif32.zip
platform = https://github.com/pioarduino/platform-espressif32/releases/download/55.03.35/platform-espressif32.zip
board = esp32-s3-devkitc-1
board_build.partitions = partitions/aq_partition_8mb.csv
upload_speed = 921600
monitor_filters = direct, esp32_exception_decoder, time, colorize
debug_tool = esp-builtin
extra_scripts = scripts/upload_monitor_delay.py
;custom_monitor_delay = 1
custom_port_timeout = 2
#lib_ldf_mode = chain+
	-DARDUINO_USB_MODE=1
	-DARDUINO_USB_CDC_ON_BOOT=1
	-DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_ERROR
	-I src/core/
build_type = debug
	bblanchon/ArduinoJson@^7.0.4
	shah253kt/SimpleStack@^1.0.0
	fastled/FastLED@^3.9.13
	lvgl/lvgl@^9.2.2
	bodmer/TFT_eSPI@^2.5.43
	ESP32Async/AsyncTCP
	ESP32Async/ESPAsyncWebServer
	adafruit/Adafruit BusIO@^1.17.1
	https://github.com/cyberreefguru/ESP32-ESP32S2-AnalogWrite.git
	;https://github.com/crgmakes/module-firmware.git#clean-room
lib_ignore = SD
[env:client10]
	${env.build_flags}
	-DVERSION=1.0.0
	-DAQ_CLIENT
	-DHW_V10
	-DBOARD_HAS_PSRAM
	-DUSER_SETUP_LOADED=1
	-DTOUCH_CS
	-DILI9341_2_DRIVER=1
	-DTFT_WIDTH=240
	-DTFT_HEIGHT=320
	-DTFT_CS=-1
	-DTFT_RST=-1
	-DTFT_DC=-1
	-DTFT_MISO=-1
	-DTFT_MOSI=-1
	-DTFT_SCLK=-1
	-DTFT_BL=-1
	-DTOUCH_SCL=-1
	-DTOUCH_RST=-1
	-DTOUCH_SDA=-1
	-DTOUCH_INT=-1
	-DSD_CS=-1
	-DLOAD_GLCD=0
	-DSPI_FREQUENCY=27000000
	-DSPI_TOUCH_FREQUENCY=2500000
	-DTFT_INVERSION_ON
	-DTFT_BACKLIGHT_ON=HIGH
	-I src/client
build_src_filter = +<*> -<.git/> -<hub/**> -<TouchDisplay.*> -<DisplayManager.*>
	${env.lib_deps}
	adafruit/Adafruit LTR329 and LTR303@^2.0.1
	adafruit/Adafruit SGP40 Sensor@^1.1.3
	adafruit/Adafruit MCP23017 Arduino Library@^2.3.2
lib_extra_dirs=
Any suggestions?
  • Please change all leading # to ; in your platformio.ini
  • Close VS Code
  • Delete the folder .pio located inside your project
  • Delete the folder /Users/uid/.platformio/packages
  • Delete the folder /Users/uid/.platformio/frameworks
  • Restart VS Code
Hello Boris - I did all that without any change.
After a lot of experimentation, I believe I figured out a solution. The environment that would not work [client] does not require the web server. I moved the web server library to the other environment’s dependencies [hub] rather than in common [env], and the compilation started working.
I don’t know why the library will not compile if the classes are not being used, but it seems to be working now. I will continue testing when I can to figure out why the library does not compile properly if the classes are not used in the source code.
Additionally, changing # to ; made zero difference.
-Tom
Ah, this explains a lot :slight_smile:
That’s a strange behavior of the LDF (Library Dependency Finder). For libraries like ESPAsyncWebServer you have to include them into your project code or remove them from the lib_deps section. Alternatively you can set the lib_ldf_mode = deep+ in your platformio.ini - See Library Dependency Finder (LDF) — PlatformIO latest documentation.
Removing the library from the environment which does not use the library at all seems to be the best way (in my opinion).
