I have a project that build with success on windows but not on MacOs
I have to build the project with C++17
My platformio.ini file
[env:seeed_xiao]
platform = atmelsam
board = seeed_xiao
bxparks/AceButton@^1.9.2
adafruit/Adafruit GFX Library@^1.11.3
adafruit/Adafruit SH110X @ ^2.1.8
adafruit/SD@0.0.0-alpha+sha.041f788250
-std=c++17
-std=gnu++17
-fexceptions
build_unflags =
-std=gnu++11
The build log:
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/seeed_xiao.html
PLATFORM: Atmel SAM (8.1.0) > Seeeduino XIAO
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
- framework-arduino-samd-seeed @ 1.8.1
- framework-cmsis @ 2.50400.181126 (5.4.0)
- framework-cmsis-atmel @ 1.2.2
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 21 compatible libraries
|-- AceButton @ 1.10.1
|-- Adafruit GFX Library @ 1.11.5
|-- Adafruit SH110X @ 2.1.8
|-- SD @ 0.0.0-alpha+sha.041f788250
|-- Bb
Compiling .pio/build/seeed_xiao/src/main.cpp.o
In file included from /Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/cstdlib:41:0,
from /Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/stdlib.h:36,
from /Users/louis/.platformio/packages/framework-arduino-samd-seeed/cores/arduino/Arduino.h:25,
from src/main.cpp:1:
/Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_vector.h:581:12: error: expected ';' at end of member declaration
end()_GLIBCXX_NOEXCEPT volatile
In file included from /Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/vector:64:0,
from lib/TinyExpr/tinyexpr.h:53,
from lib/Bb/formulaHelper.h:5,
from lib/Bb/displayHelper.h:5,
from src/main.cpp:3:
/Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_vector.h:582:7: error: expected unqualified-id before '{' token
{ return iterator(this->_M_impl._M_finish); }
Compiling .pio/build/seeed_xiao/lib43e/TinyExpr/tinyexpr.cpp.o
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/device/usbd_control.c.o
In file included from /Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:59:0,
from /Users/louis/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/vector:60,
from lib/TinyExpr/tinyexpr.cpp:50:
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/dialog/da146xx/dcd_da146xx.c.o
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/espressif/esp32s2/dcd_esp32s2.c.o
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/microchip/samd/dcd_samd.c.o
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/microchip/samg/dcd_samg.c.o
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/nordic/nrf5x/dcd_nrf5x.c.o
*** [.pio/build/seeed_xiao/src/main.cpp.o] Error 1
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/nuvoton/nuc120/dcd_nuc120.c.o
Compiling .pio/build/seeed_xiao/FrameworkArduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src/portable/nuvoton/nuc121/dcd_nuc121.c.o
*** [.pio/build/seeed_xiao/lib43e/TinyExpr/tinyexpr.cpp.o] Error 1
