When I try to build an ESP32 project on another PC I’m getting the following error log. The same project is working fine on my PC.
I need advice what can be wrong with it.
Processing esp32doit-devkit-v1 (platform: espressif32@2.0.0; board: esp32doit-devkit-v1; framework: arduino)
--------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (2.0.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 3.10004.210126 (1.0.4)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Converting smartController.ino
cc1plus.exe: fatal error: opening output file C:\Windows\system32\downloads\firmware\src\smartController.ino.cpp: No such file or directory
compilation terminated.
*** Error 1
AssertionError: :
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 180:
File "C:\Users\richa\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Script\SConscript.py", line 597:
File "C:\Users\richa\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Script\SConscript.py", line 285:
File "C:\Users\richa\.platformio\platforms\espressif32\builder\main.py", line 223:
File "C:\Users\richa\.platformio\packages\tool-scons\scons-local-4.2.0\SCons\Util.py", line 748:
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 61:
env.ProcessProgramDeps()
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 128:
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\tools\platformio.py", line 340:
env.ConvertInoToCpp()
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\tools\piomisc.py", line 240:
out_file = c.convert(ino_nodes)
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\tools\piomisc.py", line 92:
return self.process(contents)
File "C:\Users\richa\.platformio\penv\Lib\site-packages\platformio\builder\tools\piomisc.py", line 113:
assert self._gcc_preprocess(contents, out_file)
================================================== [FAILED] Took 0.80 seconds ==================================================The terminal process "C:\Users\richa\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
