I installed the LVGL library using pio pkg in the espidf project. The build is successful and menuconfig is also executed, but the LVGL configuration items are not displayed. Shouldn’t it be installed as a library in espidf?
That’s weird, when I do those steps it builds normally.
C:\Users\Max\temp\lv_port_esp32>pio run
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 (5.2.0) > Espressif ESP32 Dev Module
- framework-espidf @ 3.40402.0 (4.4.2)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 14.4% (used 47048 bytes from 327680 bytes)
Flash: [==== ] 40.1% (used 420577 bytes from 1048576 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
======================[SUCCESS] Took 81.44 seconds ======================
Make sure no antivirus is interfering with execution, that the project is not in some cloud folder (OneDrive, Dropbox, …) and that your core and platform are up-to-date. (CLI → pio upgrade --dev and pio pkg update -g- p espressif32).
Do a clean rebuild as needed by deleting the .pio folder of the project and building again.
Yes, the build was successful after clean. However, after adding the lvgl project as a submodule of the espidf project, I did pio init, and it became a strange program in which two platformio.ini were created.
So I proceeded by adding it as a component. I cloned the lvgl and lvgl_esp32_drivers repository inside the components directory with git submodule add https://github.com/lvgl/lvgl.git components/lvgl git submodule add https://github.com/lvgl/lvgl_esp32_drivers.git components/lvgl_esp32_drivers
When I run menu config, it works normally.
