Hi I’m trying to overcome the heap problem with the BLE and wifi on the esp32, currently the only solution I have found is to reconfigure the esp-idf, and rebuild the Arduino core. Well I’ve done it know but I wonder if I can build the platform io package/platform so that I can test it in PIO.
I’m just looking for a more automatic way rather than just copy all the recompiled libs and stuff like that.
Thanks
You can fork Arduino ESP32 Core, apply own changes and point PlatformIO to your own package in platform.json
(you can find it in .~/platformio/platforms/espressif32
Nevertheless, we will simplify this way soon via
Thanks that simplifies installation in platform io but how to create the package, is there a script that will copy all the required files to create a Platformio package?
btw. great job with Platform IO it’s really wonderful for tinkering
You can install packages using Redirecting... and --with-package
option. Later, you can apply patches.
You can use any language to modify files on-the fly. See Redirecting...
Just use in your platformio.ini
[env:myenv]
build_flags = !cmd_or_path_to_script
