The command line
pio init --ide visualstudio --board adafruit_grandcentral_m4
seems not to work anymore as expected.
Starting from Marlin platformio.ini already initialized with multiboard (agcm4 is already defined as environment) with above command line I get:
Error: Invalid value: invalid choice: 1. (choose from off, chain, deep, chain+, deep+) for option lib_ldf_mode
in section [env:fysetc_STM32F1]
launching PIO, using as board the one defined in env_default, it works
GMagician:
So what option is there the in this environment for lib_ldf_mode
? PlatformIO did impose stricter checking on the configuration file, as it is properly documented here ["New project configuration parser with a strict options typing "] and here . So I wouldn’t say this is a regression or a bug.
Don’t know but grand central is samd51, not stm32f1
edit: you are telling me that mega2560 compiles just because its env definition is before the one in stm32f1?
Ok, changing lib_ldf_mode value fix it. Now don’t find old value 1 what is in 4.0…maybe chain? Where can I find 3.x references about it?
See
r'^#include\s+(<|")(Arduino|mbed)\.h(<|")', flags=re.MULTILINE
# check source files
for root, _, files in os.walk(path, followlinks=True):
if "mbed_lib.json" in files:
return ["mbed"]
for fname in files:
if not fs.path_endswith_ext(
fname, piobuild.SRC_BUILD_EXT + piobuild.SRC_HEADER_EXT
continue
with io.open(
os.path.join(root, fname), encoding="utf8", errors="ignore"
) as fp:
content = fp.read()
if not content:
continue
if "Arduino.h" in content and include_re.search(content):
return ["arduino"]
if "mbed.h" in content and include_re.search(content):
[0, 1, 2, 3…]
1 = chain
P.S: Could you remove this option at all?
ok, thank you very much
it’s not up to me, it’s used in env I don’t work with. I posted a PR in Marlin with ‘chain’ to fix them
